Dave Posted July 9, 2017 Share Posted July 9, 2017 (edited) So been having a few problems with overdrive gear and revs up and down ,pulled my ECU to check the board and found I had a leaking capicitor ,can I get this repaired or is the ECU no good now ? See pics ----- to the right of the little light blue thingys Edited July 23, 2017 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
Dave Posted July 10, 2017 Author Share Posted July 10, 2017 so if your having problems i suggest inspecting your ECU ,someone also suggested having all the capicitor replaced as most of these are 20 years plus now. Quote Link to comment Share on other sites More sharing options...
scott.wild Posted July 10, 2017 Share Posted July 10, 2017 I had a similar issue a while ago, change out the capacitors and get a circuit board cleaner/spray and gently clean up the area. Hopefully all the tracks will still be connected, if not you can repair the broken tracks with wire. Quote Link to comment Share on other sites More sharing options...
Twin turbo Posted July 11, 2017 Share Posted July 11, 2017 So been having a few problems with overdrive gear and revs up and down ,pulled my ECU to check the board and found I had a leaking capicitor ,can I get this repaired or is the ECU no good now ? See pics ----- to the right of the little light blue thingys Hi send hi-res pictures to (Lscowboyls) watch my thread. He usally answer very fast. Quote Link to comment Share on other sites More sharing options...
Dave Posted July 11, 2017 Author Share Posted July 11, 2017 Got someone local sent him pics ,just waiting for a reply been highly recommended . - - - Updated - - - Hi send hi-res pictures to (Lscowboyls) watch my thread. He usally answer very fast. Thanks will do Quote Link to comment Share on other sites More sharing options...
Dave Posted July 11, 2017 Author Share Posted July 11, 2017 (edited) Hi send hi-res pictures to (Lscowboyls) watch my thread. He usally answer very fast. Can't find him in the member list Edited July 11, 2017 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
Twin turbo Posted July 12, 2017 Share Posted July 12, 2017 (edited) Here is a link if needed https://m.facebook.com/pg/LScowboyLS/about/?mt_nav=1 He will answer within hours every day and they give lifetime guarantee.they use the original caps needed. Edited July 12, 2017 by Twin turbo (see edit history) Quote Link to comment Share on other sites More sharing options...
Krister Posted July 12, 2017 Share Posted July 12, 2017 Any shop that does circuit board work like TV repair shops etc can get those changed for you. Quote Link to comment Share on other sites More sharing options...
Twin turbo Posted July 12, 2017 Share Posted July 12, 2017 Any shop that does circuit board work like TV repair shops etc can get those changed for you. Maybe but it is very important that the right caps are used since 90% is chinese fakes out there. Quote Link to comment Share on other sites More sharing options...
supra87 Posted July 12, 2017 Share Posted July 12, 2017 I'd buy a replacement ecu I had a similar issue with mine not to long ago and a replacement was cheaper than repairing it Quote Link to comment Share on other sites More sharing options...
Dave Posted July 13, 2017 Author Share Posted July 13, 2017 I'd buy a replacement ecu I had a similar issue with mine not to long ago and a replacement was cheaper than repairing it It's going in today will see what he says. Quote Link to comment Share on other sites More sharing options...
Dave Posted July 21, 2017 Author Share Posted July 21, 2017 (edited) had it done today back in sunday its pissing down at the moment,only cost me a tenner ,board has been cleaned and re laquered ,cap replaced,still gonna get me a spare one though. Edited July 21, 2017 by Dave (see edit history) Quote Link to comment Share on other sites More sharing options...
Ric Posted July 21, 2017 Share Posted July 21, 2017 can you share which place did it? Quote Link to comment Share on other sites More sharing options...
evinX Posted July 21, 2017 Share Posted July 21, 2017 I was speaking to my dad the other day about this, an electronic engineer. He seems confident he can repair mine if i ever need it Quote Link to comment Share on other sites More sharing options...
Dave Posted July 21, 2017 Author Share Posted July 21, 2017 can you share which place did it? Hi ric it was a local guy to me and he was pretty thorough ,I live in LLANELLI South Wales can give you his number if you want it mate . He repairs tv and computers as his business from his home . - - - Updated - - - I was speaking to my dad the other day about this, an electronic engineer. He seems confident he can repair mine if i ever need it As long as you catch it in time ,otherwise it will burn through the pcb. Quote Link to comment Share on other sites More sharing options...
evinX Posted July 21, 2017 Share Posted July 21, 2017 Hi ric it was a local guy to me and he was pretty thorough ,I live in LLANELLI South Wales can give you his number if you want it mate . He repairs tv and computers as his business from his home . - - - Updated - - - As long as you catch it in time ,otherwise it will burn through the pcb. You can bridge the connections with thin wire if the board gets damaged. Quote Link to comment Share on other sites More sharing options...
Guest kcoles1 Posted July 22, 2017 Share Posted July 22, 2017 Any chance of the guys number? I've got a couple that need replacing in my spare Ecu, want a working spare just incase really! Quote Link to comment Share on other sites More sharing options...
and1c Posted July 22, 2017 Share Posted July 22, 2017 You can bridge the connections with thin wire if the board gets damaged. Its got sub level traces as well though so if they get damaged the board is scrap. Quote Link to comment Share on other sites More sharing options...
Dave Posted July 22, 2017 Author Share Posted July 22, 2017 Any chance of the guys number? I've got a couple that need replacing in my spare Ecu, want a working spare just incase really! /QUOTE] PCS COMPUTER REPAIRS 07962804961 / 01554 772203. email [email protected]. Web http://www.pcs-llanelli.co.uk Quote Link to comment Share on other sites More sharing options...
Guest kcoles1 Posted July 22, 2017 Share Posted July 22, 2017 Thanks mate Quote Link to comment Share on other sites More sharing options...
Dave Posted July 23, 2017 Author Share Posted July 23, 2017 Ok the repaired ECU and it's working perfect I'm going to take it back and get all the capacitors replaced with new ones Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted July 23, 2017 Share Posted July 23, 2017 Good to hear, just make sure they replace the caps with like for like or better. Quote Link to comment Share on other sites More sharing options...
Pete Posted July 24, 2017 Share Posted July 24, 2017 It's a big problem in the retro gaming scene. Old caps leaking and destroying boards, lots of guys are getting their kit 'recapped'. At least on these ECU boards it's nice chunky components, I'd happily tackle something like that myself. (Runs off to make a note to remove the ECU soon) Quote Link to comment Share on other sites More sharing options...
