Dave Posted July 9, 2017 Share Posted July 9, 2017 Is there a guide on how to remove the ECU ,want to get mine out to check the board ,does the ECU come off the cradle or do you take the whole lot out ? Link to comment Share on other sites More sharing options...
safcdixon Posted July 9, 2017 Share Posted July 9, 2017 Theres a bolt on it iirc its at the bottom the top kinda locks in and theres one on the actual ecu loom connector Link to comment Share on other sites More sharing options...
Dave Posted July 9, 2017 Author Share Posted July 9, 2017 Theres a bolt on it iirc its at the bottom the top kinda locks in and theres one on the actual ecu loom connector Cheers can see the bolt the plugs that go into. The ECU do they pull out or do you need to remove the four little screws? Link to comment Share on other sites More sharing options...
Dave Posted July 9, 2017 Author Share Posted July 9, 2017 Theres a bolt on it iirc its at the bottom the top kinda locks in and theres one on the actual ecu loom connector Ok got the ECU loose how do you get the plugs out ? Link to comment Share on other sites More sharing options...
Wez Posted July 9, 2017 Share Posted July 9, 2017 From memory you take up the plastic cover which is held on with 3-4 nuts, then the ECU comes out attached to a tray and the plug is held in with a bolt. Link to comment Share on other sites More sharing options...
Dave Posted July 9, 2017 Author Share Posted July 9, 2017 From memory you take up the plastic cover which is held on with 3-4 nuts, then the ECU comes out attached to a tray and the plug is held in with a bolt. Thanks done it now Link to comment Share on other sites More sharing options...
