Trac vvti won't turn off.
Haeken
Hi.
Just bought myself a new Supra and when I try do a burnout or do a little drift it just cuts off.
Tha trac off light comes on in the dash when I press the button to turn it off but still cuts power, if I try a burnout with it off it kills power and takes rpm down to 2.5-3.5k or smth like that.
I do have a rltc but I also turn that off at the same time.
Dunno where to start to look :/
And just to clarify it's a vvti car so no separate trac ecu or trac fuse :/
Regards
Edited by Haeken (see edit history)
You should just be able to turn it off when you start the car,
Just hit the button before you have a play and the light should come on in the dash
Yeah, i press the TC off button and the traction controll off light comes on, but its still on and cuts power when it comes loose :/
I don't have Snow mode, maybe because mine is pre facelift ? All I have to do is hit the TC button then sorted.. try TuneR way
