Dim Sum Posted July 4, 2017 Share Posted July 4, 2017 Trying to install my Syvecs and I was hoping that the knock sensor would fit into the stock knock sensor and realised that's not the case. So does anyone know where it goes? Quote Link to comment Share on other sites More sharing options...
bignum Posted July 4, 2017 Share Posted July 4, 2017 I mounted mine towards the back of the inlet mani, theres a 12mm just underneath, as advised by Ryan g. Quote Link to comment Share on other sites More sharing options...
Mike2JZ Posted July 4, 2017 Share Posted July 4, 2017 I'm assuming syvecs uses a bosch type wideband knock sensor. In which case you can mount it to the block in the stock locations, but you will need the following stud Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted July 4, 2017 Author Share Posted July 4, 2017 I mounted mine towards the back of the inlet mani, theres a 12mm just underneath, as advised by Ryan g. Back of the inlet. 12mm is that the bolt that holds the pipe? By cylinder 4 just below the head? Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted July 4, 2017 Author Share Posted July 4, 2017 I'm assuming syvecs uses a bosch type wideband knock sensor. In which case you can mount it to the block in the stock locations, but you will need the following stud http://i163.photobucket.com/albums/t307/kclegend/IMG_6823.jpg Yeah Syvecs uses the Bosch wideband knock sensor. Thank you for the pic, I ring Toyota tomorrow with that part number and check too Quote Link to comment Share on other sites More sharing options...
