kevin smith Posted July 2, 2017 Share Posted July 2, 2017 Hi all some of you will know that since i bought my NA i have had trouble with the OD and main warning light flashing, and the car has never quite run right. I am not able to do any mechanical work due to my disability, ended up taking it to my local Toyota dealer so they could do a diagnostic check they found a couple of small mechanical bit's which they fixed because the car was just not running right. But most of all they they fixed the problem with the OD and warning lights flashing. The car is now running so well, and i am enjoying it so much i can't stop driving it again so i am going to start going to the Bluewater meet again so see some of there again. One very happy Supra owner. Quote Link to comment Share on other sites More sharing options...
curious Posted July 2, 2017 Share Posted July 2, 2017 Hi all some of you will know that since i bought my NA i have had trouble with the OD and main warning light flashing, and the car has never quite run right. I am not able to do any mechanical work due to my disability, ended up taking it to my local Toyota dealer so they could do a diagnostic check they found a couple of small mechanical bit's which they fixed because the car was just not running right. But most of all they they fixed the problem with the OD and warning lights flashing. The car is now running so well, and i am enjoying it so much i can't stop driving it again so i am going to start going to the Bluewater meet again so see some of there again. One very happy Supra owner. What was the issue with the OD light flashing ? Great to know your enjoying your supra ! Quote Link to comment Share on other sites More sharing options...
kevin smith Posted July 2, 2017 Author Share Posted July 2, 2017 They done the wire conversion at the back of the clocks and the speed converter. Quote Link to comment Share on other sites More sharing options...
