HarleyFDMD Posted June 27, 2017 Share Posted June 27, 2017 I know this isn't a particularly common thing to do, i guess primarily because GTE heads dont come up for sale very often but im sure they're atleast a couple of people that have done it? I just need to know exactly whats required. So far i have: Gte head Ge block Gte engine loom Brand new gte coils + clips Arp head studs I know i need the drive gear that i believe sits behind the crank pulley but is there anything else? Any help would be appreciated! Link to comment Share on other sites More sharing options...
berg Posted June 27, 2017 Share Posted June 27, 2017 This is the thread i followed back in the day when i had my na-t http://www.supraforums.com/forum/showthread.php?225971-NA-to-TT-Conversion-TT-head-swap-info Theres quite a bit to it The people i spoke to back in the day when i was doing the same had used the TT pistons/rods in the GE block too, as mounting the GTE head and GTE headgasket onto a GE block the compression is still not ideal In the end it made more sense for me to use the GE head and convert to coilpack etc I believe the GE head actually flows slightly better anyway Link to comment Share on other sites More sharing options...
SupraLEDrears Posted June 27, 2017 Share Posted June 27, 2017 This is the thread i followed back in the day when i had my na-t http://www.supraforums.com/forum/showthread.php?225971-NA-to-TT-Conversion-TT-head-swap-info Theres quite a bit to it The people i spoke to back in the day when i was doing the same had used the TT pistons/rods in the GE block too, as mounting the GTE head and GTE headgasket onto a GE block the compression is still not ideal In the end it made more sense for me to use the GE head and convert to coilpack etc I believe the GE head actually flows slightly better anyway This is what I'm doing but with a vvti head so i can make it look like the gte. Forged rods and pistons, plus a standalone ecu. I've been running coilpacks for ages but struggled to find a dizzy cover and it looked horrendous. Link to comment Share on other sites More sharing options...
HarleyFDMD Posted June 27, 2017 Author Share Posted June 27, 2017 I will be using a standalone ecu and either gte pistons or forged pistons Link to comment Share on other sites More sharing options...
Mike2JZ Posted June 27, 2017 Share Posted June 27, 2017 The closest you will get to the real deal is to get the following: 2JZGTE Crank Sprocket & Crank Sensor 2JZ GTE Oil Pump (The GE spring does not fit into a GTE pump from my own testing. GTE oil pump uses two springs. I'm currently about to test the pressure differences between running both and removing one whilst in use on a GE block, so can confirm correct way to proceed regarding this in my build thread soon, as people have said that GTE oil pump will push too high oil pressure on GE block due to differences in oil galleries/squirters. 2JZGTE Cooalnt Pump, Upper Coolant Neck & Coolant Bypass tube. 2JZGTE Coolant hard lines 2JZGTE Oil Filter Housing/Oil Cooler 2JZGTE Inlet side coolant outlet from block 2JZGTE Pistons & OEM Headgasket Other than that you will need a long oil feed line to go from the inlet side of the engine where the oil ports are, around to your single. You may need to think of a more creative oil feed option if you plan on running twins I've just been working on a supra that has been converted using the above, and it made over 600hp with a 6262 without any issues of knocking. So long as the building process is done correctly and the tune is done using a standalone by a good tuner then I don't see why there is any issue with this route. Link to comment Share on other sites More sharing options...
robby a Posted June 27, 2017 Share Posted June 27, 2017 I've got a new gte headgasket, used oil squirters and conrods if you need them Link to comment Share on other sites More sharing options...
Pablo Garcia Posted April 19, 2023 Share Posted April 19, 2023 So in order to run best compression for ge block with gte head, which tt headgasket thikness do u guys recomend ? Btw, sorry for coming up with this question so late xD Link to comment Share on other sites More sharing options...
