Heater matrix problems
Newsuprahunter
Ok guys got a issue with my heater system first I had no heat at all. Flushed it through with no luck. Changed the thermostat again with no luck. Then driving down the motorway there was a strong smell of fried electrics and the whole heater system went down. Next day changed the fuse (which had blown) lit up like a Christmas tree until I started the engine then the fuse blow again. Has anyone got any ideas? Is this a straight forward fix or does require a bit more detail ? Thanks in advance for any solutions you can think of.
