Dave Posted June 24, 2017 Share Posted June 24, 2017 With the brown plug on ,And should it move ? I.e. Twisting in hole Link to comment Share on other sites More sharing options...
Lee P Posted June 24, 2017 Share Posted June 24, 2017 That's an injector and yes it will twist a bit Link to comment Share on other sites More sharing options...
Dave Posted June 24, 2017 Author Share Posted June 24, 2017 That's an injector and yes it will twist a bit wheres the oil temp sensor ,cause my oil temp light came on on the way home then went off again. Link to comment Share on other sites More sharing options...
Scooter Posted June 24, 2017 Share Posted June 24, 2017 There is no (stock) oil temp light, yellow oil can is level, red is pressure. Suspect yellow and on/off due to surge (hard braking?) Link to comment Share on other sites More sharing options...
Dave Posted June 24, 2017 Author Share Posted June 24, 2017 There is no (stock) oil temp light, yellow oil can is level, red is pressure. Suspect yellow and on/off due to surge (hard braking?) It was the yellow one with the wavy lines and the red triangle checked my level all good just done an oil change.is there a level sensor ? Link to comment Share on other sites More sharing options...
Swampy442 Posted June 24, 2017 Share Posted June 24, 2017 Thats the oil level light, the sensor is on the right side of the engine, near the dip stick on the sump. Known to fail Link to comment Share on other sites More sharing options...
Lee P Posted June 24, 2017 Share Posted June 24, 2017 It was the yellow one with the wavy lines and the red triangle checked my level all good just done an oil change.is there a level sensor ? Oil level sensor is on the sump next to the dipstick Could either be a dodgy sensor or alternator has failed if you have other symptoms Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 25, 2017 Share Posted June 25, 2017 Forget oil level sensors on *ANY* engine, the dipstick always speaks the truth, the sensors can get you into deep poo poo if relied upon to warn of low oil level. Link to comment Share on other sites More sharing options...
Swampy442 Posted June 25, 2017 Share Posted June 25, 2017 Forget oil level sensors on *ANY* engine, the dipstick always speaks the truth, the sensors can get you into deep poo poo if relied upon to warn of low oil level. Ask a few E60 M5 owners Link to comment Share on other sites More sharing options...
Dave Posted June 25, 2017 Author Share Posted June 25, 2017 Forget oil level sensors on *ANY* engine, the dipstick always speaks the truth, the sensors can get you into deep poo poo if relied upon to warn of low oil level. See post 5 Link to comment Share on other sites More sharing options...
Dave Posted June 25, 2017 Author Share Posted June 25, 2017 Oil level sensor is on the sump next to the dipstick Could either be a dodgy sensor or alternator has failed if you have other symptoms New alternator will check the sensor thanks all Link to comment Share on other sites More sharing options...
