Air con Regas (how much gas)
mplavery
Going to re-gas the aircon in the Supra but want to be sure how much gas goes back in, don't want to over fill it.
Hasn't been done since I owned it which is 11 years lol still pushed out cold air though
Just done my Audi which was 550g
I had a look on line and im getting 700g but want to double check. As I had my car re-painted it looks like the sticker no longer there to tell if if it had one
cheers
I read a USA site that gave 600g as the charge weight in a Supra. If its blowing cold you don't need to re-gas it. You need expensive equipment to properly gas a car ac as it has a vacuum pump, recovery cylinder, weight scales and gauges. So if it isn't broke recommendation is don't try to fix it.
Thank mate
I have been told 750g
We have the right gear, doing it at work .. It is cold but I know it an be colder so just re gassing it as its never been done since I owned it
