PC Help
Dnk
First have you tried re-downloading Itunes (as in the installer) as sometimes they get corrupt, try with chrome rather than IE or the other way round.
Try this - uninstall anything Itunes. If it doesn't come up in the list you may have to add the package by browsing for the Itunes and other apple folders. You get a 30 day trial IIRC
https://www.martau.com/uninstaller-download.php
If not a clean install of win 8 rather than a refresh will probably be required.....
Tried it on both IE and Chrome and get the same result.
I've removed anything linked to itunes as suggested on Apples site and no joy.
Tried the uninstaller in the link and didn't find anything itunes linked
CCleaner logged this
The file referenced at: C:\Users\Andrew\Downloads\iTunes64Setup.exe.ApplicationCompany could not be located.
These references are often left behind after uninstalling software.
Solution: Delete the registry value.
Gald you're sorted.
these may help chrome etc.
https://www.asus.com/us/support/FAQ/1007486/
https://productforums.google.com/forum/#!topic/chrome/KYdoZG_pVpk
If you go here: https://www.microsoft.com/en-gb/software-download/windows10
choose the download tool, and then run it, you'll end up with a free windows 10 upgrade, still works even though they were supposed to stop it last July. Just choose to keep files etc. Depends on how PC savvy you are to get it to run nicely as you may have some driver issues, but probably not if your PC was made Win 8 era.
Care is required with Windows 10 as some older software isn't compatible, even under compatibility settings. My accountancy software doesn't run on Windows 10 so it was a decision whether to stick with what I had (avoiding the then free upgrade) or buy new software. I stuck.
Gald you're sorted.
Fixed the small address and book marks now thanks
