Marty Posted June 9, 2017 Share Posted June 9, 2017 Hey guys My mum has a braking issue on her Volvo, c30, around a 2007, 1.6d. Basically when shes driving her brakes are very spongy, sometimes she'll brake and there will be barely anything there, the pedal goes pretty much all the way to the floor, sometimes it is just fine. When it does happen if she pumps the pedal the brakes come back to life (pedal firms up) and work fine, but it'll happen again if she doesn't use the brakes for a short period. It isn't air in the system as when the engine is off the pedal is to the top and solid. I've had a little look online and there doesn't seem to be anything conclusive - some say dodgy brake booster but it seems to be working fine, the pedal would stay firm if it wasn't. I've had a look over the vac lines and all seems ok. Could this be a master cylinder issue? I've also read that it could be an abs module problem. Has anyone experienced anything similar? Thanks in advance Quote Link to comment Share on other sites More sharing options...
Shane Posted June 21, 2017 Share Posted June 21, 2017 I had these exact symptoms on two of the Mercedes I have owned, both turned out to be the master cylinder. That would be my first thing to eliminate, has it ever had a fluid change? Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 21, 2017 Share Posted June 21, 2017 I'd bleed the system if its not been done for a few years if ever and go from there, at least you can do that yourself for not a lot of cash Quote Link to comment Share on other sites More sharing options...
Marty Posted August 18, 2017 Author Share Posted August 18, 2017 Thanks for the replies guys Still not got to the bottom of this. I bought a second hand master cylinder off eBay - i cannot for the life of me find a new one anywhere, except volvo. The master cylinder was changed and the problem persists? Surely you'd think the chances of another one being toast too would be slim. Leads me to believe it could be something else. Would the fluid cause these problems? You'd think once the car was hot and fluid warm that you'd see it everytime the brakes were applied? It's intermittent:search: Quote Link to comment Share on other sites More sharing options...
jagman Posted August 18, 2017 Share Posted August 18, 2017 There is a Volvo recall on the brake check valve -intermittent brake servo assist and pedal pressure - 2007 cars on Quote Link to comment Share on other sites More sharing options...
Marty Posted August 18, 2017 Author Share Posted August 18, 2017 (edited) There is a Volvo recall on the brake check valve -intermittent brake servo assist and pedal pressure - 2007 cars on I did spot that on the volvo website and forwarded the info on to my mum, she said that her vin came back with no recalls? I assume if that if the brake check valve was faulty the pedal would still stay firm and the brakes just not work as well? The pedal on my mums volvo will literally go straight to the floor sometimes with very little braking there. You have to let off and put your foot down again for the brakes to work. I've seen it before on older cars where the rear drum was faulty, the ratchet mechanism that holds the shoe close to the drum had failed, it was backing off between braking causing a similar issue. This volvo has the ratchet type pistons in the caliper, maybe worth looking at? Can't say i've ever heard of them fail. I'd still be convinced it was the master cylinder if i hadn't have swapped it, maybe the other one could be faulty? I don't really want to drop £300+ in to one supplied by volvo just to have the same problem i have come across this too.. http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=517A1A55A2A84BD0802574020030A0C0&freeText=Blank maybe it is the master cylinder:rolleyes: Edited August 18, 2017 by Marty (see edit history) Quote Link to comment Share on other sites More sharing options...
croboy Posted July 20, 2020 Share Posted July 20, 2020 I did spot that on the volvo website and forwarded the info on to my mum, she said that her vin came back with no recalls? I assume if that if the brake check valve was faulty the pedal would still stay firm and the brakes just not work as well? The pedal on my mums volvo will literally go straight to the floor sometimes with very little braking there. You have to let off and put your foot down again for the brakes to work. I've seen it before on older cars where the rear drum was faulty, the ratchet mechanism that holds the shoe close to the drum had failed, it was backing off between braking causing a similar issue. This volvo has the ratchet type pistons in the caliper, maybe worth looking at? Can't say i've ever heard of them fail. I'd still be convinced it was the master cylinder if i hadn't have swapped it, maybe the other one could be faulty? I don't really want to drop £300+ in to one supplied by volvo just to have the same problem i have come across this too.. http://www.vosa.gov.uk/vosa/apps/recalls/searches/expand.asp?uniqueID=517A1A55A2A84BD0802574020030A0C0&freeText=Blank maybe it is the master cylinder:rolleyes: Yo, did you ever find out the issue? I'm having something similar with my jza80 Quote Link to comment Share on other sites More sharing options...
rider Posted July 27, 2020 Share Posted July 27, 2020 Yo, did you ever find out the issue? I'm having something similar with my jza80 Marty isn't one of our more frequent posters so they may well not be a regular site visitor so they probably won't pick up on your question. You really need to private message him, but unfortunately, you'd need to join up and pay a small subbscription fee in order to send a PM. Alternatively, you can raise your own specific thread question in the Supra technical section and that would probably illicit replies - it could even then be picked up by Marty seeing it'd be profiled as a new topic. Quote Link to comment Share on other sites More sharing options...
