Base Map for Syvecs
Dave Carroll
Hi guys,
Wondering if there is anyone who can help me out.
Essentially, my car is going in for mapping next Thursday, but want to get the car running on a base map beforehand to ensure everything works as it should.
I bought the plug and play kit from Whifbitz, but there is no base map installed.
Spoken to my mapper who agreed to make a base map but its taking longer than I would like.
Anyone have a map file they could email me?
Build spec:
Borg warner sxe369 twin scroll
Whiftbitz manifold
Straight through blitz nur spec r
V160
1000cc asnu injectors
Twin 450lph walbro pumps and lines
Stock block
264 in/out cams
Syvecs s6gp
Oil pressure sensor
Fuel pressure sensor
Flex fuel sensor
Wideband lambda
3 port boost solenoid
Any thing someone has that will just let me get it idling and revving to check for leaks etc is perfect.
Cheers
David
Hi David
I have a map for a Precision 6466 turbo on syvecs running 1100cc asnu injectors manual v160 and twin pumps. Any use to you?
/QUOTE]
Hi Sheefa,
If my understanding is correct, being for larger injectors it should be good. Might be perfect in fact.
If you could send it to me via email would be a massive help!
Thanks so much!
David
Edited by Dave Carroll (see edit history)
