Drivers window poor fitment help needed
brom86
If it's standard Toyota..
You need to take the door card off and ensure the window is actually sitting in the frame.
It maybe the winder has play.. or the plastic adapter that the window sits in has broke.
As above, take the door card off and you have 3 bolts attaching the window to the window regulator which adjusts how the window sits.
Took me a good 30 - 40 minutes setting it back up when I had to change mine over, was a right pain.
