mrboomberang Posted June 1, 2017 Share Posted June 1, 2017 Does anyone with the blitz nur exhaust pass an mot Link to comment Share on other sites More sharing options...
ben_harmer32 Posted June 1, 2017 Share Posted June 1, 2017 are you worried about noise or emissions? Link to comment Share on other sites More sharing options...
mrboomberang Posted June 1, 2017 Author Share Posted June 1, 2017 Emissions Link to comment Share on other sites More sharing options...
evinX Posted June 1, 2017 Share Posted June 1, 2017 CAT back? or full? My NA has a catback HKS silent, 1st and 2nd cat in, and passes. Last time it was 0.1 out on the 2nd pass, they warmed up the lambda as it would of cooled down and went right through, i replaced my lambda and 2nd cat this year so expect it to go through 1st time on both passes. Will see as im due and im 1996 so conform to the more stricter emissions Link to comment Share on other sites More sharing options...
KamaSupra Posted June 1, 2017 Share Posted June 1, 2017 My Blitz Nur Spec R with a 2nd decat goes through ok every year. Link to comment Share on other sites More sharing options...
mrboomberang Posted June 1, 2017 Author Share Posted June 1, 2017 CAT back? or full? My NA has a catback HKS silent, 1st and 2nd cat in, and passes. Last time it was 0.1 out on the 2nd pass, they warmed up the lambda as it would of cooled down and went right through, i replaced my lambda and 2nd cat this year so expect it to go through 1st time on both passes. Will see as im due and im 1996 so conform to the more stricter emissions No cats on mine Link to comment Share on other sites More sharing options...
mrboomberang Posted June 1, 2017 Author Share Posted June 1, 2017 My Blitz Nur Spec R with a 2nd decat goes through ok every year. So you still have have the first cat? Link to comment Share on other sites More sharing options...
ben_harmer32 Posted June 1, 2017 Share Posted June 1, 2017 what year is yours? mine past MOT few weeks ago with double decat Link to comment Share on other sites More sharing options...
Annabella Posted June 1, 2017 Share Posted June 1, 2017 what year is yours? mine past MOT few weeks ago with double decat If its the same as in his sig it's 1997, and TT so will need a cat I believe as they can cross reference the UK turbo, and it's 96 onwards for additional emissions. Link to comment Share on other sites More sharing options...
mrboomberang Posted June 1, 2017 Author Share Posted June 1, 2017 Mines a 1997 gets classed as uk tt Link to comment Share on other sites More sharing options...
BoGlE Posted June 1, 2017 Share Posted June 1, 2017 Find a friendly tester Link to comment Share on other sites More sharing options...
KamaSupra Posted June 1, 2017 Share Posted June 1, 2017 So you still have have the first cat? /QUOTE] Yeah I still have the 1st cat fitted, as I can't be bothered with fitting and removing for mots. Link to comment Share on other sites More sharing options...
evinX Posted June 1, 2017 Share Posted June 1, 2017 Mines a 1997 gets classed as uk tt /QUOTE] Beacuse thats probably all theirs lists...93-96 jza80 like alot of uk based garages. Theres another class for a import i forget what it is. Link to comment Share on other sites More sharing options...
mrboomberang Posted June 1, 2017 Author Share Posted June 1, 2017 Find a friendly tester /QUOTE] He used to be a friendly tester but is getting less friendly and more worried about losing his licence Link to comment Share on other sites More sharing options...
mrboomberang Posted June 1, 2017 Author Share Posted June 1, 2017 Beacuse thats probably all theirs lists...93-96 jza80 like alot of uk based garages. Theres another class for a import i forget what it is. This sounds interesting Link to comment Share on other sites More sharing options...
mrboomberang Posted June 3, 2017 Author Share Posted June 3, 2017 I've left the first cat on hopefully it should pass Link to comment Share on other sites More sharing options...
conorj Posted June 3, 2017 Share Posted June 3, 2017 Mine went straight through on Thursday with double decat, no questions asked MOT is meant to be stricter over here too Link to comment Share on other sites More sharing options...
evinX Posted June 3, 2017 Share Posted June 3, 2017 Mine struggled the other day. My mot tester suspected it was all blocked up and got the tester to blast it up and down the lot. Back into emissions and it went right through. Guess i dont open her up enough lol Link to comment Share on other sites More sharing options...
mrboomberang Posted June 10, 2017 Author Share Posted June 10, 2017 Put on the oem from first decat cat to back box it failed not by much for reference to anyone else Link to comment Share on other sites More sharing options...
