Help please - temporary clutch/flywheel
Sheefa
Hi all
Given my clutch issues in going to have to remove and fully inspect everything. I'm convinced something is knackered with the plates or there's a manufacturing fault given only covered sub 600 miles from new.
I want to do an immediate swap over to keep the car running but naturally don't want to bite the bullet on a new clutch if the existing one is to be replaced under warranty or at least until fully inspected to see what's going on. I want to keep the car on road just to drive back home too.
Has anyone got a cheap stock/other working clutch and compatible flywheel for a 6 speed I can borrow or purchase. Ideally borrow as I wouldn't be running ANY boost and would return shortly after but if cheap enough don't mind buying one to keep me going.
Help! Thanks all.
Greg :(
I have a single plate one you can borrow if you want mate? not sure what type as for what its rated to but I was running over 700bhp and over 600 ft lb of torque on it before and had no slip and always gripped perfect anyway :) gimmie a message if you wanna borrow :)
