jaha66 Posted May 23, 2017 Share Posted May 23, 2017 Started the supra tonight normally takes a good while to warm up headed for the petrol station 3 min away temp gauge half way (Not normal).checked water none. Started the car turned heater on filled with water and it's pissing out behind the engine coming down behind the oil sump. Could it be a core plug ?? Thanks Quote Link to comment Share on other sites More sharing options...
Scooter Posted May 23, 2017 Share Posted May 23, 2017 Could be but i'd say (more gut instinct than experience mind) that they are more likely to weep or be a less noticeable leak, it could be the hose that comes up out of the rear of the head. Is it a TT or NA? and can you be more specific or the area it's leaking or even where it's definitely not leaking from. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted May 23, 2017 Share Posted May 23, 2017 Ill say its the pipe at the back of the cylinder head, for the heater Quote Link to comment Share on other sites More sharing options...
jaha66 Posted May 23, 2017 Author Share Posted May 23, 2017 Its a single turbo. I jacked it up and that's where it is running down right in the centre. Couldn't see were from the top of the engine. I had a na before and it blew a core plug out. Quote Link to comment Share on other sites More sharing options...
jaha66 Posted May 23, 2017 Author Share Posted May 23, 2017 Is it far down swampy Quote Link to comment Share on other sites More sharing options...
keron Posted May 23, 2017 Share Posted May 23, 2017 heater matrix pipe as above at a guess.... one in the center on the head. change loads of them. they split where the clamp goes on it on the head side. Quote Link to comment Share on other sites More sharing options...
jaha66 Posted May 23, 2017 Author Share Posted May 23, 2017 Il get a better look tomorrow. Cheers lads. You got any new ones in stock keron? Quote Link to comment Share on other sites More sharing options...
keron Posted May 23, 2017 Share Posted May 23, 2017 yep in stock.... take the spark plug cover off and move the pipe a little and see if its leaking in the middle. the water can come into the spark plug area too and flood the plugs = misfire. very common Quote Link to comment Share on other sites More sharing options...
jaha66 Posted May 23, 2017 Author Share Posted May 23, 2017 Must be then she was misfiring.be in touch thanks for the help Quote Link to comment Share on other sites More sharing options...
jaha66 Posted May 24, 2017 Author Share Posted May 24, 2017 Keron checked that pipe there no leaks checked all the top and side pipes that are visible all dry I just filled the rad and didn't start car and it's running out from further down. ????? Quote Link to comment Share on other sites More sharing options...
