terribleturner Posted September 25, 2005 Share Posted September 25, 2005 Am i right in thinking that behind one of the glove boxes i can gain access to a pre made hole in the fire wall?? Need to pass a couple of wires through into the engine bay. Link to comment Share on other sites More sharing options...
Jake Posted September 25, 2005 Share Posted September 25, 2005 Behind the top glove box is where the loom comes through into the car. Or there's another one lower down but you need to take the wheel arch liner out to get to it. Easiest is the rubber grommit where the clutch cable goes (or would go if your car is an Auto) Link to comment Share on other sites More sharing options...
terribleturner Posted September 25, 2005 Author Share Posted September 25, 2005 Thanks Jake, may use the Clutch cable entrance then. Link to comment Share on other sites More sharing options...
SimonB Posted September 25, 2005 Share Posted September 25, 2005 There is a yellow grommit each side up in the inner wing area. If you look under the bonnet there's a hole in the inner wing each side near the firewall with a plastic bit of trim round. If you peer in there you'll see the grommit - it comes out high up under the dash (easier to see on the drivers side). Link to comment Share on other sites More sharing options...
Scrote Posted September 25, 2005 Share Posted September 25, 2005 Drivers side on an auto Link to comment Share on other sites More sharing options...
terribleturner Posted September 25, 2005 Author Share Posted September 25, 2005 Will have a look at that one too Simon. Cheers Scrote, i'm staring and staring at that picture but for the life of me can't work it out. Think my brain has been dried up at work today Will have to get under the bonnet with a tourch tomorrow and see what's being used and what isn't. Link to comment Share on other sites More sharing options...
Scrote Posted September 25, 2005 Share Posted September 25, 2005 The pics at a funny angle, rotate 90 deg. anti clockwise. Get on your back & it'll make sense. Link to comment Share on other sites More sharing options...
MONKEYmark Posted September 25, 2005 Share Posted September 25, 2005 i had a picture of a stunt rider going through a wall of fire.then was dissapointed to see it was a grommit lol Link to comment Share on other sites More sharing options...
terribleturner Posted September 25, 2005 Author Share Posted September 25, 2005 Get on your back & it'll make sense. That's what my girlfriend said I think i get it. Will all be clearer when i get in there and have a look though. Link to comment Share on other sites More sharing options...
how_supra Posted September 26, 2005 Share Posted September 26, 2005 That's what my girlfriend said which girlfriend? Link to comment Share on other sites More sharing options...
terribleturner Posted September 26, 2005 Author Share Posted September 26, 2005 Had a look at where the clutch cable was meant to go and the hole wasn't there. The heast resistant material stuff on the inside of the wall had a hole cut in the correct place, but not in the actual fire wall. Went another route in the end so alls well that ends well Link to comment Share on other sites More sharing options...
Jake Posted September 26, 2005 Share Posted September 26, 2005 Had a look at where the clutch cable was meant to go and the hole wasn't there. That's unpossible Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted September 26, 2005 Share Posted September 26, 2005 That's unpossible is that a new word Link to comment Share on other sites More sharing options...
terribleturner Posted September 26, 2005 Author Share Posted September 26, 2005 is that a new word That's what i was thinking No Jake i swear. I'll try to get a picture taken when i get home. That's unless i wasn't looking in the right place, but there's nothing else visable in that area Link to comment Share on other sites More sharing options...
