Fulcrum2000 Posted May 18, 2017 Share Posted May 18, 2017 In my ongoing quest to get my 93 JDM TT fully up to spec before going BPU I've been trying to get my aircon working. I had it checked and the condenser was snafoo so after having to import one from the US (kaching) and having it fitted, my mechanic filled the system with UV marked gas and both pipes have leaks on corroded ends - does anyone know where I can get these two pipes, I've even tried Toyota and can only find one. If anyone can help I'd appreciate it so much. Also how do you get a picture on your profile, everyone has their Supe and I want to put mine up but cant find it in the settings anywhere. Quote Link to comment Share on other sites More sharing options...
rider Posted May 18, 2017 Share Posted May 18, 2017 Any decent refrigeration engineer can fabricate/change plumbing or replace compression olives. Take it your mechanic isn't a refrigeration engineer, which begs the question where did he get the gas from as you have to be a certified refrigeration engineer since 2015 to buy refrigerant in cylinders. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 18, 2017 Share Posted May 18, 2017 Any decent refrigeration engineer can fabricate/change plumbing or replace compression olives. Take it your mechanic isn't a refrigeration engineer, which begs the question where did he get the gas from as you have to be a certified refrigeration engineer since 2015 to buy refrigerant in cylinders. Maybe he bought a refill can from halfords [emoji39] Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 18, 2017 Share Posted May 18, 2017 Get them off keron. You can be a certified refrigeration engineer and change pipes, change parts and gas/empty cars and not be able to make up new pipes. All of us at work are certified but don't have the equipment to make hoses. We just use new parts or get them made up at pirtek. Which by the way would be your alternative if you can't get a hose from keron....local pirtek will make you one. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 18, 2017 Share Posted May 18, 2017 Get them off keron. You can be a certified refrigeration engineer and change pipes, change parts and gas/empty cars and not be able to make up new pipes. All of us at work are certified but don't have the equipment to make hoses. We just use new parts or get them made up at pirtek. Which by the way would be your alternative if you can't get a hose from keron....local pirtek will make you one. [emoji40] [emoji32] [emoji33] yuk pirtek !!!!!! Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 18, 2017 Share Posted May 18, 2017 Lol, it's a franchise so I guess there are good and bad ones. Our local one is really good. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 18, 2017 Share Posted May 18, 2017 Lol, it's a franchise so I guess there are good and bad ones. Our local one is really good. Naaaa they are good I work for hydroscand a competitor lol Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 18, 2017 Share Posted May 18, 2017 Ahh I see [emoji3] Quote Link to comment Share on other sites More sharing options...
Fulcrum2000 Posted May 19, 2017 Author Share Posted May 19, 2017 Yes, just to confirm my garage are of course certified they're the only one where I live that will touch a Supe too, all the others seem terrified. As I bring mine up to spec I'm trying to use genuine parts as much as humanly possible even if it means importing though. Who is Keron, I assume he's on here? Quote Link to comment Share on other sites More sharing options...
jackso11 Posted May 19, 2017 Share Posted May 19, 2017 That's his name on here, trader section - Extremeperformance Quote Link to comment Share on other sites More sharing options...
