HELLBOY666 Posted May 17, 2017 Share Posted May 17, 2017 I'm wanting to get my inlet manifold, rocker covers and a few other bits painted in my engine bay but the alloy wheel company who can cook and powder coat for me said it will only take around 200 degrees should this be enough ??? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 17, 2017 Share Posted May 17, 2017 200c is fine, i painted most of my engine peripherals with 2k paint, also painted bike engines in it, no need for powder coat. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 17, 2017 Author Share Posted May 17, 2017 200c is fine, i painted most of my engine peripherals with 2k paint, also painted bike engines in it, no need for powder coat. Cool but if I could have it powder coated for cheap would the 200c be good enough? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 17, 2017 Share Posted May 17, 2017 The only thing that likely to go over 200c is the exhaust manifold and turbo housing, if the engine block reached 200C it would be seriously overheating, think about the oil and coolant temps, oil temp will not go over 120c unless pushed. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 17, 2017 Author Share Posted May 17, 2017 The only thing that likely to go over 200c is the exhaust manifold and turbo housing, if the engine block reached 200C it would be seriously overheating, think about the oil and coolant temps, oil temp will not go over 120c unless pushed. Sweet I'll be going for a powder coating and I know the question was a bit of a dum one but powder coaters asked the question before they do anything lol [emoji106] [emoji12] Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted May 17, 2017 Share Posted May 17, 2017 Just be very careful if you have the manifolds and valve covers powder coated. I'd they are going to be media blasted, you'll have to drill the baffles out, and make sure no media is left behind. Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 18, 2017 Author Share Posted May 18, 2017 Just be very careful if you have the manifolds and valve covers powder coated. I'd they are going to be media blasted, you'll have to drill the baffles out, and make sure no media is left behind. /QUOTE] Was gonna get them soda blasted I'd that any different? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted May 18, 2017 Share Posted May 18, 2017 Soda blasting is much safer, and water soluble, so I guess as long as the part is fully washed out afterwards, it should be fine? I've heard horror stories about sandblasting in the past! Quote Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 18, 2017 Author Share Posted May 18, 2017 Soda blasting is much safer, and water soluble, so I guess as long as the part is fully washed out afterwards, it should be fine? I've heard horror stories about sandblasting in the past! /QUOTE] [emoji106] [emoji16] Quote Link to comment Share on other sites More sharing options...
