New and Used Toyota OEM Parts – Big Clearout
dandan
I have loads of parts left over in the garage and am going to keep updating this list as I get them out and photographed.
Will add pics as soon as I can for the parts that need it....
Still Available
Full set of top mounts, bumpstops and isolators - £100 plus postage
Chris Wilson front springs – slightly lowered and stiffer, barely used. £50 plus postage
Selection of suspension cam bolts as pictured £10
Rear suspension top mount covers – sit inside boot £5 posted
Full set of facelift dash panels – very good condition (will get pics) £220 or best offer plus postage
Facelift clock £30
Facelift four spoke steering wheel £120 or best offer (needs to be collected)
Pair of leather arm rests from GZ – great condition £100 or best offer plus postage
Passenger side electric window switch and panel to fit to armrest £10 posted
AC control unit £25 posted
Exhaust manifold studs 90080-12011 x5 £10 posted
Clutch pedal footrest - £10 posted
Power steering pump – used but spins freely £20 posted
Set of used jap spec hybrids – previously on Leon Green’s Supra – need rebuild. £200 or best offer plus postage
TT water neck elbow £25 posted
Set of cam buckets with various thickness shims - £20 posted
Exhaust tunnel bracket £10 posted
Facelift non vvti manual ECU £90 or best offer posred
Facelift non vvti trac ECU £15 posted
Six used coil packs £60 posted
Passenger side gunmetal door handle £15 or best offer posted
Pair of boot rubbers (lower) 67293-14051 £10 posted
Clutch release bearing 90363-45012 and two clips £25 posted
Flywheel bolts (x8) 90910-02103 – for W558 I think £35 posted
Gearbox front inner seal 90069-08001 £10 posted
Pair of camshaft seals 90311-40020 £25 posted
Full set of injector seals (can supply part numbers as there are several) £30 posted
Gasket for plenum to runners 17176-46030 £8 posted
Gasket for runners to head £10 posted
Manual TT main engine undertray £100 plus postage
Brand New V160/V161 Slave Cylinder – NA Size Bore for NA or TT. Great for less throw on the clutch pedal, had one on my car. £40
Stock turbo pipes as pictued, without VSVs - £50 plus post
Fan hub - £35 posted
Provisionally Sold Pending Payment
Black boot carpet with “flap” for cubby hole - £70 plus postage (trying to add pics now)
Used V160/V161 Slave Cylinder – TT £30
Sold
Brand New Toyota Front Anti Roll Bar Rubbers - £5
Brand New Toyota Cam Belt - £15
Brand New Toyota Exhaust Manifold Gasket – TT 17173-46040 - £15Sidemount intercooler £80 plus postagePair of Brand New Toyota UK Spec Brake Caliper Pistons – 47731-14120 £10
Set of UK rear caliper seals 04479-14130 £5
Full set of valve stem seals (24x grey and 24x brown) £70 posted
Freshly powdercoated pair of black engine lift hooks £10 posted
Sidemount intercooler brackets and main duct £20 posted
Rear anti roll bar rubber mount bushes £5
TT Radiator/Fan shroud with lower clip on piece £75 posted.
Brand New Toyota TT Bottom Rad Hose - £5
Brand New Battery Clamp Bracket – for UK size batteries – 74404-14321 - £20
Pre-Facelift Engine Mounts,bought from JamieP many moons ago to replace my facelift ones as I think the pre-facelift ones are a bit stiffer or stronger – can’t remember exactly now. I never used them as I sold the car. £75 including postage.
I will take please as below:
Pmd offer ok
PM'd you back, thanks.
New TT slave cylinder please
The TT one is used, about 65k miles and only removed as I changed to an NA spec one to suit my clutch. The NA one listed here is brand new (fits TT and has shorter throw on pedal but bit stiffer underfoot). Which one are you after?
Do the engine mounts come with the brackets required to fit them to a facelift car? If so I'm interested
Yes, they have brackets mate. Just added a photo so let me know if they are what you need.
I would take the Battery Clamp if hasn't neen Sold already
PM'd you dude, I think it is sold to blythmrk though.
Pm'd you bud re exhaust gasket
All sorted :thumbs:
Ill take the engine mounts if still available
Also, you had a diff rebiuld kit at one point did that sell?
Sorry mate, mounts are gone. Not sure about the diff kit. I will have a look around - still wading through loads of stuff...
PM'ed about the rad shroud :)
- - - Updated - - -
and the bottom rad hose please :)
No problem, pm'd you back with PP details.
Still waiting for pm with payment details!
If you want to pay for the bits you definitely want that works for me, just let me know. I think you're waiting on the intercooler pics before you decide on that though and I'm having issues uploading anything at the moment. Will try again in an hour or so.
Oh dear
:D
