Oil weep
Jellybean
One of my pet hates ,
Car is sat up 2 weeks now , tiny weep under the car , trail from rear subframe alone SRD undertray
Oil residue on top of the sump area , where the dip stick resides
Cam covers are all dry , no leaks , rear water pump , engine undertray below oil pump has zero oil residue, oil filter is all dry
Oil dipstick was removed from the sump a few months ago ; would a worn O ring cause enough blow back or what else around there can I check?
Sump , oil pump was all sealed with toyota black sealant , I do not think it is the sump
