Headlight restoration
Supra-love
As we all know our plastic Jap lenses cloud and grab oxidisation.
Mine were no exception, I gave them a good machine polish but wasn't enough.
As you can see my passenger side was still rather cloudy..
So I split the headlights using the oven on a temp of 100 degrees, and tin foil to stop any melting.. I then used a screw driver and worked my way around to pull apart, I then reheated at same temp with the same process in the oven to remove all the sealant. (Or as much as I could)
They already had Matt black sprayed innerds but where the lense had pushed against the inserts I had flat spots, so I've gloss blacked them now! Using tetrosyl gloss black. 1can! Still drying as you can see!
Go the lenses I used a 600grit paper, then some fine, used lapping paste I got from work.
Got home from work, then used green top 3m compound and das machine polisher on the inside and outer lense.
Absolutely great result, just one more lense to do them reassemble with new sealant.
Will update when assembled and then fitted.
Oven time was around 2-5mins but I was cautious so kept checking and prying as I could.
I went onto reseal the light with auto sealant
This is the finished result, I might even do a finer compound finish once fitted to the car, but I will snap a shot when fitted to the supra later this week.
As you will see I didn't de-line them as I wanted to keep the original look and avoid dispersed light!!
Edited by Supra-love (see edit history)
Can you recommend a product to clear coat with. A Google search resulted in all kinds of stuff, and even articles saying never do it.
Just use a good quality wax.
I sanded mine last year, started with 1000 grit all the way up to 7000. Then Meguiars PlastX and finally a coat of Meguiars NXT Tech Wax.
Any time I wash and wax the car I do the lights as well.
Been perfect now for over a year.
