DANWB Posted May 8, 2017 Share Posted May 8, 2017 Hi I am in desperate need of your help!! It’s a 2jzgte Toyota supra auto now converted to manual (R154) The Modifications Full Decat, I’m not proud but a eBay special exhaust middle and rear (which I hate) HKS fuel cut defender, blitz dump valve, front mount intercooler, electronic boost controller, induction kit and a lightened flywheel with a standard clutch with a R154 transmission. The way it drives, after doing the conversion (which was a while ago and tbh I can’t remember it running great back then) to get the car started I had to trick it in to thinking it’s in neutral and connected the two necessary wires together (as I’m sure your aware)so whilst its stood still if i put my foot flat to the floor it will only rev up to approx. 3000 to 4000RPM unless if I press the accelerator on off on off quickly then it will redline. Accelerating say in 2nd gear first turbo is there pulling not amazing but pulling whilst whistling etc. and it will only rev up to about 5000RPM it sounds like its hitting the limiter (I think as its difficult to concentrate) the second turbo will not come online. I’ve replaced a couple of pipes going to the solenoids (4mm internal depth pipe) in hope that there split and that hasn’t made any difference. One of my thoughts is whilst driving does the car still think it’s in neutral so its limiting the running? I hope I have put in enough info to help the situation and thanks everyone in advance for the help (alternator has also just died id thought I mention that) Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 8, 2017 Share Posted May 8, 2017 I bet it's just battery and Alternator seen as it's been sat for so long Link to comment Share on other sites More sharing options...
mellonman Posted May 8, 2017 Share Posted May 8, 2017 Sounds like a coil pack clip to me , but must be something to do with the trans change as thats whats been changed Link to comment Share on other sites More sharing options...
DANWB Posted May 8, 2017 Author Share Posted May 8, 2017 I have one on the way so its certainly worth a go :-) I hope its as simple as that. - - - Updated - - - excuse my ignorance coil pack clip? Link to comment Share on other sites More sharing options...
Andrew K Posted May 8, 2017 Share Posted May 8, 2017 (edited) Can get them from Whifbitz http://www.garagewhifbitz.co.uk/toyota-878.html?___SID=U Need replacing when old as get really brittle and end up causing a Misfire. Edited May 8, 2017 by Andrew K (see edit history) Link to comment Share on other sites More sharing options...
DANWB Posted May 9, 2017 Author Share Posted May 9, 2017 OK thanks for you help I will try to get one sorted Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 11, 2017 Share Posted May 11, 2017 I would remove the HKS FCD and see what happens if the coil connectors are OK. I would also be SURE to sort the charging issues before doing anything else. Link to comment Share on other sites More sharing options...
Annabella Posted May 11, 2017 Share Posted May 11, 2017 Thought this was a piss take on NA's. Link to comment Share on other sites More sharing options...
DANWB Posted May 12, 2017 Author Share Posted May 12, 2017 ahh thanks I will do this tomorrow and see how it goes, the alternator has been replaced and now charging which is great thanks for your help - - - Updated - - - lol nope Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 12, 2017 Share Posted May 12, 2017 ahh thanks I will do this tomorrow and see how it goes, the alternator has been replaced and now charging which is great thanks for your help - - - Updated - - - lol nope Are you still having issues m8 Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 The charging is all sorted now thanks it's just the performance did you get back OK? Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 13, 2017 Share Posted May 13, 2017 (edited) The charging is all sorted now thanks it's just the performance did you get back OK? Yeah bud got bk ok but i think I need to check plugs glad it was that simple for the charging problem and performance wise just on the off chance have you checked your earth my old white supra had that lack of power and earth was loose [emoji106] Edited May 13, 2017 by HELLBOY666 (see edit history) Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 Ah that's good I'm pleased you got back OK and ohh I haven't which earth is it? Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 13, 2017 Share Posted May 13, 2017 Ah that's good I'm pleased you got back OK and ohh I haven't which earth is it? The one straight from the battery .. myn went bk under my battery tray Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 Awsom cheers will I'm going to be busy tomorrow morning lol Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 13, 2017 Share Posted May 13, 2017 Awsom cheers will I'm going to be busy tomorrow morning lol Good lol and you have a pm m8 Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 Pm? Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 13, 2017 Share Posted May 13, 2017 Pm? I've private messaged you bud Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 I thought that's what you meant I haven't had a message through though? Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 13, 2017 Share Posted May 13, 2017 I thought that's what you meant I haven't had a message through though? Pm me bud I've sent you my number Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 It won't let me grrrr are you on Facebook? Link to comment Share on other sites More sharing options...
HELLBOY666 Posted May 13, 2017 Share Posted May 13, 2017 It won't let me grrrr are you on Facebook? No m8 txt malcom he will give you my number lol Link to comment Share on other sites More sharing options...
DANWB Posted May 13, 2017 Author Share Posted May 13, 2017 Lol will do Link to comment Share on other sites More sharing options...
