door lock button
lovatt
has anybody ever had a problem with there door lock/un-lock button on the drivers door ? it will not lock or un-lock the doors manually but my clifford still locks and unlocks them with the engine on/off. all the central locking with the key fob still works to.
dont know if this might have caused it but i was letting a bird out my car and she kept on pulling the handle as i was trying to un-lock it using the button, after this it wouldnt work.
any ideas on things to check will be a help :thumbs:
i thought it might be a rod, gonna have to strip it all down and have a look, if a rod had come off the button solonoid i dont think the alarm locking would work though ?
as for the sexual favours they had allready been recieved ;) :p
I had this too Lovatt.....exactly the same(different bird i think!:) )
Take off the door card, unplug the wiring that goes to the key barrel,you'll see the multi-plug about 7 inches below the key lock.This will make your central locking button work correctly every time! It will also work correctly with the keyfob, what you will of unpluged is the key switching for the central locking on the key barrel,which is not really needed with a remote.Let me know if this works for you. Al.
thanks for the advice and thanks for the PM supra-al :thumbs:
i found out what is was today, before i had chance to have a good look at it my lecy windows got stuck down outside work this morning so i had to have a look, nothing had broken the plug had come off the switch, it must have come off at an angle so the lock button came off before the window switch :baa: well at least it was a nice easy cheap fix :D
