Misfire help
JayJay1374
Hi everyone. Currently having a misfire problem and it's getting the better of me. Misfires on boost over 1bar, bpu car running 1.2 normally. If I control the throttle and don't go full throttle it's ok as long as it's below 1 bar.
So late last year I developed a misfire running ngk bkr7eix plugs. Fast forward to this year and I still have the misfire (the car was off the road over winter).
Anyway so I changed the plugs for a set of BKR8EIX and alas the misfire was still there. But it was different. The misfire seemed to stay between 3500-5800 rpm then pick up as normal after. So I went to fueling next. The car has had the 12v fuel pump mod done with a relay. To rule this out I removed the relay and returned to standard. I also changed the plugs to denso ik22's so I'm back in the 7 heat range.
So the misfire disappears. Awesome! Well it returned a week later. So I've checked the plugs (seem ok). Tired my old bkr7eix in and still a misfire, checked all the wiring I altered removing the 12v mod. All ok. I've changed the fuel pump ecu. Again no change. I've even tried changing the fueling back to 12v and still no change.
I want to get a multimeter on the pump and make sure it's defiantly getting the correct 9v at idle and I will bridge the obd port to check the 12v supply.
Have I bought the wrong plugs? Ik22's?
The only thing that changed was the plugs and 12v mod.
Any help or advice is appreciated.
The "clips" are just the plastic body holding the actual terminals, have yiou cut back a little way into the coil pack loom and fitted new terminals that you can buy from Toyota with factory crimped on wire tails? I would do that next, and if there's no improvement get the HT traces looked at on a scope, unless you feel lucky and diagnose by throwing bits at it ;) The coil loom terminals should be considered service items these days.
Chris I did fit replacement terminals when doing the clips as my wiring looked worse for wear.
Ok so I have borrowed a known working set of coilpacks of safcdixon and it runs perfectly. No miss at all.
So next port of call is to swap 1 coilpack out at a time to see if it's just 1 or a mix of a couple and after that source replacements.
Good to hear it's fixed and not surprised it's coil packs but would suggest you renew them all if you can.
  • 2 weeks later...
