Jamesy Posted May 19, 2017 Author Share Posted May 19, 2017 I haven't had the time to swap my cars in and out of mine yet (as I did promise and will post pics of the mkiv in there when I do) but unzipped it enough to climb inside mine at the week end to take a look how well preserved my Mkiii Supra has faired whist stored in the Carcoon (it did instantly deflate onto the roof as I had to zip it up from the inside with me inside but within a minute or so it was back up to normal with me inside). The car was exactly as I put it in at the beginning of December last year no dust corrosion on the discs etc. I cannot stress how impressed in am! Although I would like to see a drive in/out one that remains more like a tent. I cannot comment on the life span but would expect a good few years at the price charged. I think the filters have to be changed on a 12 month basis (they are only a few £'s) Hi mate don't spose you had time to take any pics and test time yet? I was going to go for a size 4 but on reflection it literally only gives 20cm distance clearance - that's 10cm front and 10cm back. Seems to be that 1. its going to make it harder to drive on and line up, and 2. more chance of it rubbing against the front and back bumpers over time. The size 5 is an extra 35cm giving you 55cm car clearance - 27cm front and rear, seems much better...... Link to comment Share on other sites More sharing options...
Jamesy Posted May 23, 2017 Author Share Posted May 23, 2017 I'm 100% in for one if we can get 10% discount. /QUOTE] They said usually 5 for a group buy but i reckon 3 should be ok Link to comment Share on other sites More sharing options...
Kopite Posted November 23, 2017 Share Posted November 23, 2017 Bump - i'm up for ordering one if a group buy is still being suggested? Link to comment Share on other sites More sharing options...
Jamesy Posted November 23, 2017 Author Share Posted November 23, 2017 still not got mine out the box!!!!!!!!! Link to comment Share on other sites More sharing options...
blythmrk Posted November 23, 2017 Share Posted November 23, 2017 My mkiii supra is tucked up in mine I wish I had owned one years ago! The only down sides are they are bulky to store when not in use and time consuming to get vehicles in and out but other wise great Link to comment Share on other sites More sharing options...
Jellybean Posted May 13, 2018 Share Posted May 13, 2018 Did you guys , get one in the end ? Looking at getting one Link to comment Share on other sites More sharing options...
Pete Posted May 15, 2018 Share Posted May 15, 2018 Did you guys , get one in the end ? Looking at getting one Yep. It's been up since around August and I've been very impressed with it. Aside from the snow collapsing it as you'd expect. It's relatively sheltered away from wind where it is so I've not had concerns in storms. I sprayed UV protector (designed for boats) the other day as it will get sun bleached eventually and this should help prevent that. The car looks great every time I take it out. Link to comment Share on other sites More sharing options...
Jellybean Posted May 15, 2018 Share Posted May 15, 2018 Taking it in and out Pete , is it a PITA? Does it take up much room , it will be on the driveway in a housing estate ; I am more concerned its an eye sore and attracts unwanted attention In terms of powering it , I read they come with a trickle charger for your car battery , you place the Carcoon Transformer in the Carccon to keep out of the elements ; I presume you run an extension lead to a plug socket ; how do you protect the power unit from the elements? Link to comment Share on other sites More sharing options...
Pete Posted May 16, 2018 Share Posted May 16, 2018 Taking it in and out Pete , is it a PITA? Does it take up much room , it will be on the driveway in a housing estate ; I am more concerned its an eye sore and attracts unwanted attention In terms of powering it , I read they come with a trickle charger for your car battery , you place the Carcoon Transformer in the Carccon to keep out of the elements ; I presume you run an extension lead to a plug socket ; how do you protect the power unit from the elements? It's not a huge PITA. There's a zip all the way around at floor level. It easier if there's two of you an no wind when putting it over the car, but it's not a big deal for one either. I just prefer not to drag it over the paint if I can avoid it. It helps if you can store the thing easily somewhere without having to fold it up too much whilst you're out in the car. Mine fits fine in the garage with the Tiger. The base slides under the car, the top next to it. I should add that I rarely go out in the Supra nowadays which is maybe why I find it easy to live with, but I do regularly uncover it to do the odd job, start it up etc. Yes it looks very obvious outside the house, but we live in a quiet cul-de-sac and it's stepped back out view of the neighbours. It is fairly large when it's puffed out as you'd expect. I guess it does look odd to anyone that happens to visit. Not sure how I'd feel about it if I lived in a busy town - I suspect some to$$er would slash it for kicks depending where you live. I use one of those intelligent chargers on mine, not the one that it comes with so can't vouch for that, but the two fans work away quietly on the PSU by roll up extension lead. It's in front of the garage so comes out under the garage door. The power sits inside the Carcoon so it's not in the elements. Link to comment Share on other sites More sharing options...
blythmrk Posted May 16, 2018 Share Posted May 16, 2018 They are great for dry dust free storage but I wouldn’t like to be using mine like a garage as it’s around a 20/30min job to take it out and get another car in. They are bulky when not I use too even the box they come in is large enough. Snow kills them too! If you have room I would put the money towards a garage (even a concrete section one) if it’s for regular use but that’s my personal opinion. Link to comment Share on other sites More sharing options...
Jellybean Posted May 16, 2018 Share Posted May 16, 2018 Thanks for the advice , and taking to time to respond! Decisions to make Link to comment Share on other sites More sharing options...
