GTR Fever Posted May 3, 2017 Share Posted May 3, 2017 Hello everyone, Took my Supra for a spin and noticed that the left rear indicator is not working (blinker/ indicator blinks faster now). So I checked the bulb, it's good. Still changed it and it does not work. Any ideas? It's a NA/ TT swap auto supra if that helps in this case. Cheers. Quote Link to comment Share on other sites More sharing options...
muckyman Posted May 3, 2017 Share Posted May 3, 2017 put your hazards on and check all four corners. The faster blinking normally indicates (pun intended) a problem with one of the other bulbs not working Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted May 5, 2017 Author Share Posted May 5, 2017 With the hazards on, all but the left rear work. Tested the socket and it's not getting power. Quote Link to comment Share on other sites More sharing options...
Noz Posted May 5, 2017 Share Posted May 5, 2017 Broken wire somewhere clearly. Track the wire back throughout the car. Worst case situation you will have to run a new feed to the rear from the front. I've never checked the wiring but that would fix the issue if you can't trace the wiring or find the supply. Quote Link to comment Share on other sites More sharing options...
GTR Fever Posted May 8, 2017 Author Share Posted May 8, 2017 Thanks man. Was wondering if there was a fuse or relay somewhere that I was missing. Will update accordingly. Quote Link to comment Share on other sites More sharing options...
