Thoughts on power steering cooler
Mgrene
The other day I wanted to allocate my oil cooler and when I removed the intercooler, I found this power steering cooler.
To me the state of the cooler looks awfall. Would you reccomend to change it? If yes, what do you reccomend?
The car is only going to be used on normal road/high way. But I doubt that it works at all :-/
I have absolutely zero experience with coolers for the power steering hence all feedback is highly appreciated.
Is the PAS cooler loose? It looks it. It does look quite rusted although it's difficult to tell for certain from the image.
PAS? Assume it is abbreviation for the cooler? Sorry I'm from Denmark so not familiar with all the words :-)
It is not loose, or actually it is just hanging there but it is installed to pipes etc.
I have used a strip to hold it up so there willl be no unnecessary pressure on where it is connected to the pipes.
cooler looks to have been angled to clear something as the stock cooler is horizontal as standard, but i'm sure it's cooling as well as any!?
It's still horizontal if you ask me, or close to be horizontal.
It is not in the way of anything :-)
Guess it is as it should be then. Just a little rusty.
