aluminim cross member n/a turbo difference?
jonny mac
hi guys, is there a difference between the n/a auto the tt auto front aluminium cross members?
I've been looking at engine mounts online and apparently there are some differences?
<!--url{0}-->[/img]</p><p> </p><p> </p><p> I
Also what about the actual brackets on the engine? I've seen a few different styles of them
There are two types of engine mount and they use different brackets, but they are the same overall height/depth whatever you want to call it but are facelift/non facelift types and NOT NA/TT types as you've labelled them.
The one you've listed as NA is a facelift (worse type) engine mount, the other is a prefacelift mount. The engine bracket for the prefacelift differs to the facelift (basically you must have matching engine mounts and their specific brackets.)
As far as I'm aware the front subframes ali and steel parts are identical for NA or TT.
sweet, so for me using my 2jz ge n/a auto engine brackets from my 1994 prefacelift, i'll need to find vibratecnics engine mounts for the n/a prefacelift?
i was going to fit a 2jz gte from an aristo soon and just want to make sure i can use my existing mounts providing i don't mix them up
