2jz fuel injector recomendations for high power
jonny mac
hi guys, I'm looking for some advice from those of you using large cc fuel injectors
they need to be top feed 14mm top and bottom, 60mm length
here's the spec of my car:
1jz head, non vvt, massive port job done
264 bc cams, bc springs and retainers
2jz block
forged pistons and rods (20cc)
6 boost manifold and a gtx3582r turbo, t3 divided collector, .8 exh housing into 3" v band and 3" exhaust
hypertune style intake with 90mm throttle body and 3" cooler/pipes
basically I'm looking to make a bucket load of power at 2 bar, turbo rated to 650bhp but I reckon I could make more
I'm using link g4 ecu stand alone so it doesn't matter if they are high or low impedance,
I have two bosch 044 fuel pumps and a walbro lift pump to swirl pot so fuel pressure isn't an issue
I've been looking at injector dynamics 1050x new style injectors?
what do you all use/power do you make at what duty cycle ?
and where did you get them? and what would people recommend, this is my last piece of the puzzle in my build so I'm more than happy to wait for the right thing
