Air con pump
bayside_supra
I would start by taking it back to where re gassed it for you. Ask them to pressure test the system and make sure the gas/refrigerant is still present.
If they have just regassed your AC system without checking for leaks first and all that refrigerant has just leaked out into the atmosphere thats a very big no no. Huge fines can apply, not for you but for them
  • 4 weeks later...
All a/c units have a pressure sensor for the clutch circuit, so it won't run if the system pressure falls below a certain positive pressure; usually around 11psi. This is to prevent the a/c compressor sucking in atmosphere if a major leak in the system were to occur. I'd suspect a faulty pressure sensor. Whoever fitted your new pump and recharged you refrigerant should be able to check the sensor is good, or not so good.
Whoever said it was the pump should pay for your pump.
Dude you needed to check the control side before changing any parts.
Check that the wiring to the magnetic clutch is reciving a signal before anything else.
If it is then power up the clutch manually to check activation.
If not then make sure the pressure switches are being switched.
These will kick out the system so stoping the signal to the magnetic clutch being turned on.
Hope that helps
Of course there are simpler things to check first, like the 10A clutch fuse. Have you checked that is OK, mind you if its blown aside from a bare metal short that would usually indicate a compressor partial or full seizure problem. There is a relay as well that you can short (bypass) with a paperclip to force the clutch to engage. Maybe your relay is frazzled, 20 year old relays can fail? Always best to check fuses and relays before tackling the hardware.
