2JZ-GTE VVTI engine with Turbos
Hassan
Hi ive got a 2JZ-GTE VVTI engine for sale. Its out of my 2000 Toyota Aristo. Engine has only done 65,000 Miles. Regularly serviced. Only ever used shell V-Power 99ron in it. Just had a new crank pulley fitted. Engine is in perfect working order. No smoke on start up or miss fires. Pulls very strongly through the rev range. Engine will be sold with all the auxiliaries and turbos.
This engine has also got the Premium Japan throttle body installed. It deletes all the drive by wire and gives you full physical control off the throttle. So your right foot does all the throttle control and not the ECU. Will sell separately for £400
Can post up or send videos off engine running.
£3000 + Shipping
