jza800 Posted April 22, 2017 Share Posted April 22, 2017 (edited) Hi I have a troble supra on my hands, it have some power sterring issue, i feels like the powersterring only works half as it should.. the fluid is 2 years old, so i tried to change it, i could see the filter in the powersterring reservoir was very dirty, so i clean it with brake cleaner, and took the airhose to push the dirt out off the reservoir, after that i had no powersterring at all, but all off a suddon the powersterring came all back and now it worked 100% as it should.. but it dident work very long, and how i am back where i startede as it only work half as i should.. what could the problem be? has the dirt move to another part on the sterring system or??? Edited April 29, 2017 by jza800 (see edit history) Quote Link to comment Share on other sites More sharing options...
Scooter Posted April 23, 2017 Share Posted April 23, 2017 Few ideas You can have a hose that is perished and let's air in which foams the fluid up. You could have a fluid leak, but you'd have probably noted this by now. You could have fluid leaking into the rack bellows. Your crank pulley might be partially seperated and so not providing enough drive to the the pump Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 23, 2017 Author Share Posted April 23, 2017 You can have a hose that is perished and let's air in which foams the fluid up. -> all lines looks ok, there is foams in the reservoir when i turn side to side, when there was air in the system, but that is gone now. You could have a fluid leak, but you'd have probably noted this by now. ->No leak on the system. You could have fluid leaking into the rack bellows. ->If that was the case, should i not use fluid? as it dosent do that. Your crank pulley might be partially seperated and so not providing enough drive to the the pump ->I have testet that too, with 2 yellow lines on the pully to see if it moves, and the lines is the same place after a hard drive. so that shuld be ok.. Quote Link to comment Share on other sites More sharing options...
jza800 Posted April 26, 2017 Author Share Posted April 26, 2017 bump Quote Link to comment Share on other sites More sharing options...
Dave Posted May 9, 2017 Share Posted May 9, 2017 Did you bleed the system when you put new fluid in ? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 11, 2017 Share Posted May 11, 2017 You say it's solved, it would be useful for forum members if you were to say HOW you solved it please! Quote Link to comment Share on other sites More sharing options...
Frank Bullitt Posted February 24, 2019 Share Posted February 24, 2019 So how did you solve this problem? Quote Link to comment Share on other sites More sharing options...
jza800 Posted February 24, 2019 Author Share Posted February 24, 2019 wire problem to the motor on the sterring rack.. Quote Link to comment Share on other sites More sharing options...
