Facelift auto box
Mac Srt
j_jza80 (http://www.mkivsupra.net/vbb/member.php?20146-j_jza80) is running a single turbo on his tiptronic box set-up via a Syvecs ECU although I am not too sure on his power level. Torque and excessive heat is apparently what causes issues due with weak components inside the box but these can be upgraded.
People have been running in excess of 500lbft without issues but if you launch the car hard and abuse the box don't expect it to last long past this level.
DavidP offers a Hybrid box, contact him for more info if this interests you. Loads of info here - http://www.mkivsupra.net/vbb/group.php?groupid=57
AFT Speed/IPT are probably the most experienced autobox rebuilder but are state side. Although if you can source the parts any competent autobox company should be able to do it.
If you want to spend big £££'s upgrading the internals you could look at ATF Speed (http://www.atfspeed.com). I am not sure if they use their own Raybestos Blue Plates in their rebuild or if they use the ones from Import Performance Transmissions (http://www.importperformancetrans.com/catalog/toyota-lexus-transmission-rebuild-kit/a340-aw4-rebuild-kit-w-raybestos-blue-plates--1785.html). IPT also offer a valve body mod.
If you have some spare time, here are some informative videos to watch.
[video=youtube;z4Ix-vt3sps]
Edited by Frank Bullitt
Links added. (see edit history)
