Dial Warning Lights when swapping to Syvecs - Slip Cont + Cruise
Big Mark
About to order a dial kit for my car and I asked them what is the difference between J-spec and UK dials and got sent the image above.
But, as my J-Spec car doesn't have Cruise control and the factory traction control will be binned once Syvecs is fitted am I right in thinking that "Slip Cont Off", "Slip Cont" and "Cruise" lights are all redundant, so I could order custom dials without these, or do they perform other uses?
Edited by Big Mark (see edit history)
In principle yes, I had the UK clocks to fit so I could integrate the fog light in and manually add in the syvecs traction control (never got round to it), so you could have a custom dial with some wiring from the syvecs (unsure if you may run out of I/O ports?).
