Gasket for rear spoiler install
wrighty338
Hi
Just had a trd rep wing painted up and taking the old oem spoiler off i notice it has its own rubbery/foamy gasket - is there anything i can use on my new spoiler to do the same? not really sure what its called? has anyone done something similar and if so what did you use?
cheers
Jon
I used adhesive backed neoprene foam sheet on mine but was so long ago can't recall exactly what
Something like this, the base of the TRD wing supports dont fit the tailgate that well
so the thicker foam works better imo as it squashes down unlike harder rubber sheet
http://www.ebay.co.uk/itm/ADHESIVE-BACKED-BLACK-NEOPRENE-SPONGE-FOAM-RUBBER-SHEET-2mm-12mm-THICK-/262928953459
