Big Supes Posted April 17, 2017 Share Posted April 17, 2017 Sorry... didn't want to start another thread, but felt the two items I am asking for advice on needed to be kept separate. I'm after a compressor for my garage to power the odd air tool but to, ultimately, be able to respray a car with no issues. Anyone out there with something ideal? Link to comment Share on other sites More sharing options...
mwilkinson Posted April 17, 2017 Share Posted April 17, 2017 I bought one of these and for the money it's a steal. http://www.ukhs.tv/Dakota-14-CFM-Air-Compressor I use it to run a soda blaster in a frost blasting cabinet. It does this without issue. It also runs of a 13a supply. Don't know about spraying a car, but I'm sure it would be OK. Might look for the 150 ltr model. Link to comment Share on other sites More sharing options...
Big Supes Posted April 17, 2017 Author Share Posted April 17, 2017 mwilkinson said: I bought one of these and for the money it's a steal. http://www.ukhs.tv/Dakota-14-CFM-Air-Compressor I use it to run a soda blaster in a frost blasting cabinet. It does this without issue. It also runs of a 13a supply. Don't know about spraying a car, but I'm sure it would be OK. Might look for the 150 ltr model. Looks pretty decent for the money, indeed. Those specs will be good enough to respray a car for sure. Thanks mate. Link to comment Share on other sites More sharing options...
rider Posted April 17, 2017 Share Posted April 17, 2017 The only thing you need to look at when buying an air compressor is the cfm rating. Anything at or above 14 and you will be fine running most air tools. Spray painting you can get away with lower. A decent size receiver tank is a useful buffer, to give you more time before running out of puff if your air tool uses more air then the compressor can replensih. I always go for 14 cfm with a 50l minimum tank. Useful giude http://www.specialisedwelding.co.uk/manuals/Air_Compressor_Manuals/Air%20Tool%20Consumption%20Guide.pdf Link to comment Share on other sites More sharing options...
Big Supes Posted April 17, 2017 Author Share Posted April 17, 2017 Yep. Most people seem to think 12-14 cfm is adequate for spraying for a car. Link to comment Share on other sites More sharing options...
mwilkinson Posted April 17, 2017 Share Posted April 17, 2017 FYI it comes with two female Euro connectors. I've retained the Euro connectors but you might need to change these if you have existing equipment. Link to comment Share on other sites More sharing options...
Big Supes Posted April 17, 2017 Author Share Posted April 17, 2017 mwilkinson said: FYI it comes with two female Euro connectors. I've retained the Euro connectors but you might need to change these if you have existing equipment. That's worth knowing, thanks. I only have an air blower tool, but I don't think it's difficult to change the fitting. Link to comment Share on other sites More sharing options...
mwilkinson Posted April 18, 2017 Share Posted April 18, 2017 Big Supes said: That's worth knowing, thanks. I only have an air blower tool, but I don't think it's difficult to change the fitting. Fittings are cheap as chips from eBay or amazon. I have also bought an inline pressure regulator/moisture trap. The compressor does have an inbuilt regulator, so you could just get a moisture trap but I wanted the regulator to be away from the compressor and closer to the blast cabinet. Link to comment Share on other sites More sharing options...
Big Supes Posted April 18, 2017 Author Share Posted April 18, 2017 Yeah, I'll definitely grab a few fittings from eBay or if they have some down at Machine Mart when I'm over there tomorrow. I'll definitely get a moisture trap for the time being. When it comes to purchasing the spraying equipment I'll look into what is the best set up for the job. Link to comment Share on other sites More sharing options...
Big Supes Posted April 18, 2017 Author Share Posted April 18, 2017 Order placed. Thanks for the recommendation Wilkinson! Link to comment Share on other sites More sharing options...
mwilkinson Posted April 18, 2017 Share Posted April 18, 2017 Glad to be of assistance. I hope it does what you need. Link to comment Share on other sites More sharing options...
