Dave Posted April 17, 2017 Share Posted April 17, 2017 Been out in the supra today 50 miles each way ran perfect on the way down but on the way back the overdrive wouldn't kick in played with the button but still not working ,dropped to 50 for a camera zone and it kicked in ,and was alright after that,anyone got a clue ,sensor or something ?.. Quote Link to comment Share on other sites More sharing options...
evinX Posted April 17, 2017 Share Posted April 17, 2017 Mines intermittent to, done the pink wire mod, no flashing flight but still intermittent Quote Link to comment Share on other sites More sharing options...
Dave Posted April 17, 2017 Author Share Posted April 17, 2017 Mines intermittent to, done the pink wire mod, no flashing flight but still intermittent Yeah I done that mod too never had a problem before,with the O/D gear Quote Link to comment Share on other sites More sharing options...
evinX Posted April 18, 2017 Share Posted April 18, 2017 To be fair i never use O/D i always find on journeys i use more fuel so never use it Quote Link to comment Share on other sites More sharing options...
brassbones Posted April 18, 2017 Share Posted April 18, 2017 I only use it for a bit of extra umph when there's a bellend bugging me Quote Link to comment Share on other sites More sharing options...
Dave Posted April 18, 2017 Author Share Posted April 18, 2017 For motorway driving it's a fuel saver 4K revs in D 3k revs in OD it's a no brainer Quote Link to comment Share on other sites More sharing options...
Dave Posted May 6, 2017 Author Share Posted May 6, 2017 Could it be a sensor or relay ? Quote Link to comment Share on other sites More sharing options...
Dave Posted May 7, 2017 Author Share Posted May 7, 2017 Done diagnostic on the auto box and no codes showing ,checked all the wiring still won't shift into OD I'm stuck Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2017 Share Posted May 8, 2017 I would check the auto box oil level, correctly, engine running in Park, first. Quote Link to comment Share on other sites More sharing options...
Dave Posted May 8, 2017 Author Share Posted May 8, 2017 I would check the auto box oil level, correctly, engine running in Park, first. Thanks Chris will check the levels tonite ,I've just swapped the TPS ,and it's running a little high on tickover ,would that make a difference ? Haven't set it properly will have to do that also . Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2017 Share Posted May 8, 2017 The TPS setting is critical to many aspects of the engine and gear box control strategies. I hope you haven't twiddled any throttle stop screws as well??? You MUST reset the TPS sensor STRICTLY following the workshop manual. if you've twiddled throttle stop screws without a reference to return precisely to, you are in a pickle... The TPS being set wrong can and will affect the auto box control... Quote Link to comment Share on other sites More sharing options...
Dave Posted May 8, 2017 Author Share Posted May 8, 2017 The TPS setting is critical to many aspects of the engine and gear box control strategies. I hope you haven't twiddled any throttle stop screws as well??? You MUST reset the TPS sensor STRICTLY following the workshop manual. if you've twiddled throttle stop screws without a reference to return precisely to, you are in a pickle... The TPS being set wrong can and will affect the auto box control... Ok set the TPS and revs are now steady at 650-700,put the original back on which I marked up before I took it off ,haven't touched the throttle stop screws, I read it's a no no .just got to take out for a test . Quote Link to comment Share on other sites More sharing options...
