Can Anyone Help Me With This Syvecs Question?
a98pmalcolm
Hey all,
I'm just resetting up my Frame Content in Custom CAN as I downloaded the new datasteam file for my Toucan display and all the settings have gone for my Dash2 Display.
I have done everything except for column 4 row 14 which need to be KnockStatus(U) but its not in the list.
If I load up my current DAT file (before importing the new JTI datastream) its in there but if I try to change it (to see where it is on the list so I can find it for my new file) it says "Warning - Inavalid Calibration Value"
1st pic is my current uploaded file to the ECU.
2nd pic is what I'm currently trying to sort before uploading to Syvecs.
If you still have the old map before you changed it, you can try paste cal to bring the info over
Hit P then L
Select the original map
Then while your on the canbus data stream screen load the settings back in.
Hit P Then I to import
