masterfett Posted April 12, 2017 Share Posted April 12, 2017 Make: Supra TT Auto Model:RZ Year: 93 Facelift: no Mileage: 171,335 (Car was imported in 2007 and import certificate shows 140,000km so since it has been converted to read miles it has covered fairly little) MOT remaining: August 2017 Service history: some Car's location: Somerset Modifications: Whifbitz Stage 1 turbos Double Decat (Both CATS included with sale) Blitz LM induction kit blitz nut spec r exhaust system (usual dents underneath, and has a flat spot on the tip) Blitz Dual SBC boost controller UK Brakes Glass Headlights Clear front indicators Grenade 17" Alloys (r34 skyline Replica wheels) And is subtlety lowered. Good bits: Drives lovely. had the following done by whifbitz mid 2014. CLEVITE ENGINE BEARING SET TOYOTA SUPRA OIL PUMP LARGE O-RING SMALL O-RING K&N OIL FILTER TOYOTA FRONT CRANK SEAL TOYOTA CAM COVER SEALS TOYOTA REAR CRANK SEAL CLEANER TOYOTA CRANK PULLEY GATES 2JZ CAMBELT 8 TOYOTA FLYWHEEL BOLT TOYOTA DRIVE PLATE TOYOTA SUPRA CRANKSHAFT TOYOTA AIR FILTER PIPE/CLIPS BLITZ LM AIR FILTER KIT COIL PACK BRACKET TOYOTA COIL PACK CLIP TOYOTA COIL PACK WIRE WHIFBITZ 2JZ COIL PACK SET 6 COIL PACK BRACKET BOLT FERREA 2JZ VALVE STEM SEALS TOYOTA CAMSHAFT SEAL TOYOTA POWER STEERING PIPE TURBO OIL DRAIN HOSES SUPRA TURBO INLET GASKET SUPRA TURBO OUTLET GASKET WHIFBITZ TURBO LINK PIPES - BLACK ARP MAIN STUD KIT ARP ROD BOLT KIT PCV VALVE SEAL CAM COVER BREATHER HOSES PCV BREATHER HOSE SILICON VACUUM HOSE TOYOTA BOV HOSE WHIFBITZ HEATER HOSES WHIFBITZ RESTRICTOR RING WHIFBITZ 1.3 BAR RAD CAP UK SPEC FRONT BRAKE DISCS UK SPEC FRONT BRAKE PADS WHIFBITZ STAGE 1 TURBOS TOYOTA MANIFOLD TO TURBO GASKET TURBO TO Y-PIPE GASKETS NEW RADIATOR WHIFBITZ 71 DEG THERMOSTAT + all the appropriate oils and fluids etc. Had 4 new falken tyres late last year, so plenty of tread left. Bad bits: Paintwork is not very good, it is suffering from laquer failing on the bonnet and the roof. Could do with a respray! Has a dent on the passenger side side skirt Interior is starting to look a little tired, and is missing the "jesus" handle and one of the plastic vents on the passenger side. Drivers Seat electric seat motor only works on one side, adjusted it manually and seems its only me that drives it, has never botherd me that much. Drivers window regulator has failed and needs replacing. Nur spec has the usual dents underneath but is also slightly flattend on the tail tip. The rear seat delete could do with being replaced, or rear seats being put back in. Seat belts are still in the car. Other: The car was an on going project that I had really hoped on finishing, however with the imminent arrivial of my first born and a house to renovate its just not going to happen anytime soon. mechanically it drives lovely and since its last MOT, last august I think I have done about 700 miles. Sadly however the bodywork is not the best, the bonnet in particular needs a respray however the whole car could do with it in order to make it the best it could be. It has blemishes and swirl marks etc as to be expected from a 23 year old car. I have a Walbro 255 fuel pump and XS power FMIC, and a spare diff that will be included with the sale. Needs a FCD in order to turn the boost up, something along with the fuel pump and fmic I had intended on getting round to but never did. plus side is the hybrid turbos have never seen more than stock boost. If it sells to a forum member i will put the car through a service. PRICE £9500 Please PM for contact details. Link to comment Share on other sites More sharing options...
sr38 Posted April 12, 2017 Share Posted April 12, 2017 Pm'd Link to comment Share on other sites More sharing options...
NickAMW Posted April 20, 2017 Share Posted April 20, 2017 Pm'd Link to comment Share on other sites More sharing options...
Lewmc93 Posted May 27, 2017 Share Posted May 27, 2017 Pm'd Link to comment Share on other sites More sharing options...
suprano Posted May 27, 2017 Share Posted May 27, 2017 Not sure if this bloke is still selling we had arranged to meet and he just never got back to me Link to comment Share on other sites More sharing options...
masterfett Posted May 28, 2017 Author Share Posted May 28, 2017 Not sure if this bloke is still selling we had arranged to meet and he just never got back to me /QUOTE] Yeah sorry about that, was busy having a baby. Which as you can probably appreciate was a little more important. Link to comment Share on other sites More sharing options...
