Another offset question
CarlT67
I'm possibly looking at a set of Works
Sizes will be 9.5j ET +35 front
10j ET +35 rear
These will fit I believe and look pretty nice. Is this enough of a stagger front to back?
The only other option is 10.5j on the rear but that comes in a +20 offset which I don't think will fit??
What size wheels? 18" or 19"
Also might be good to put down what tyre size you planning to use
18" Something like 245 front 275 Rear
10j +35 will be fine
10.5j +20 wont fit atall. You'd need rolled arches, mad camber and stretched tyres to get that under the arch
/QUOTE]
I thought that would be the case no chance of fitting with them offsets.
Ok so the picture below is a 10j with an offset of +25
I have rolled arch that allow me to run the lower offset.
Your potential wheel specs with the +35 offset will sit 10mm further into the arch.
I would hazard a guess that that would sufficiently clear stock arches but if not the very most you would need would be a very minor arch roll.
Again with the front,
The below picture shows an 8.5j wheel with a +10 offset. Again i have rolled arches.
Your potential 9.5j et35 would sit 12mm further into the arch and again i would guess that would be ok but at the very most you'd possibly need a minor arch roll.
https://uploads.tapatalk-cdn.com/20170412/1b8ee74050ac9d9547291723137cdc57.jpg
https://uploads.tapatalk-cdn.com/20170412/e32503b33e06881683e7b3fafd42c24d.jpg
/QUOTE]
Thanks very much for your help!
