Quiet Squeaking/Creaking Noise
TomWeight
So lately I've been getting a very slight sqeaking/creaking noise coming from what I believe to be either something in the engine bay (unlikely) or most likely the front left suspension.
I just wanted to ask if anyone else has experienced the same and found the cause?
Hoping for some good news because my bank account is cowering in fear over what I believe is about to be a very expensive suspension repair lol :help:
Could be a number of things and we'll only be guessing at what it could be, when does it happen ?
Does it alter with rpm ? if you rev the engine when stationary does it do it ?
Or is it only when being driven ? does it change with speed ? going over bumps ?
No I tried that a couple of days ago, it's non-existent when stationary so it only occurs when moving.
That's what's confusing me, it doesn't seem to worsen when going over bumps or when the suspension is under extra strain such as on particularly rough roads.
Mine was creaking form the front right area under weight shifts (every time i applied the brakes) both the right hand subframe bolts inside the aluminium bit were loose!!! Once torqued no more creak.
I then checked the rest for safety and piece of mind
I have a jittery squeaking noise coming from the front too.
Happens when the car is both stationary (idling) and when moving, especially on a rough surface.
Checked what I could but couldn't find anything.
I'm thinking engine mounts as its a facelift model.
I believe the mounts have a tendency to fail.
Had this said to me about mine last time it was at Whiftbitz but it's more of a rumbling vibration than a squeaking but depends on how far gone it is
