hemmjonny Posted April 11, 2017 Share Posted April 11, 2017 Hi Guys, My car is at the garage at the moment having a few bits sorted. they have taken out the gearbox to fit a OEM clutch at the moment is has a HKS clutch and flywheel installed but its like a light switch and makes it a bit difficult in slow moving traffic and hill starts etc (i just look like a tit) So the guy was going to fit my clutch today but the flywheel is also HKS so i need one for the OEM Clutch what options have i got? or is my only option a new £536 oem flywheel? Thanks Jonny Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 13, 2017 Share Posted April 13, 2017 If the HKS is a push type clutch you will need lots of other bits that were removed and probably lost or thrown away that are needed to operate the PULL type stock clutch. You will almost certainly need the right flywheel bolts, too. - - - Updated - - - If the HKS is a push type clutch you will need lots of other bits that were removed and probably lost or thrown away that are needed to operate the PULL type stock clutch. You will almost certainly need the right flywheel bolts, too. Quote Link to comment Share on other sites More sharing options...
hemmjonny Posted April 14, 2017 Author Share Posted April 14, 2017 Thanks Chris. Yeah there was lots of extra bits I needed lol. And there is me thinking all I needed was the oem clutch how wrong I was. Found a fly now so hopefully Monday it can get back on the road. Quote Link to comment Share on other sites More sharing options...
