j spec rear brakes size...
ShawnPreece
What size diameter wheels are you looking at ?
J spec rears fit inside 16" diameter wheels
Its 15x10 wheels im after, I didnt know until the other day that the inner barrel sizes vary so I had to find out what the diameter at the largest point of the brakes was so I can compare that to the inner barrel dimension of the wheel to see if they clear
The j spec rear discs are 307mm or 12.08", looking at photos the caliper looks like its more than 1" out radially from the disc
so it'll be very close to the inside barrel of a 15" diameter wheel.
But the inside barrel will vary from wheel to wheel in profile and thickness of the material so one
15 wheel will fit where as another wont
Thanks mate yeah I spoke to a member yesterday and got a measurement and it is really tight I can see why some will fit and some wont, just need to make sure I get one with enough clearance on the inside barrel now, probably will be welds from a preliminary look
Mine fit 15" weld rears
Yeah think welds is what il be going for, im speaking to Lee atm and just asked if they can come in a powdercoated finish so I can get them as close as possible to my other wheels
