Realistic Pricing of Car.
masterfett
As above really!
Sadly I have to sell my supra, I have been putting it off for some time now, but with the birth of my first born due in less than a month, and the need for at least one sensible car and no garage I just cant justify keeping it.
Problem that I have is that I don't know how to realistically price it! I don't want to give it away but at the same time some of the prices I have seen recently just seem a little far fetched, so I'm hoping some of you guys can weigh in and maybe give me an idea of how to price it.
Its a 202 Black 94 TT Auto.
Mileage is around 171,000 km / Miles.
I bought the car back in 2014 after selling my NA5, It was a non runner, or should I say it ran but it had some issues! I promptly sent the car off to paul at Whifbitz and it had the following done.
CLEVITE ENGINE BEARING SET
TOYOTA SUPRA OIL PUMP
LARGE O-RING
SMALL O-RING
K&N OIL FILTER
TOYOTA FRONT CRANK SEAL
TOYOTA CAM COVER SEALS
TOYOTA REAR CRANK SEAL
CLEANER
TOYOTA CRANK PULLEY
GATES 2JZ CAMBELT
8 TOYOTA FLYWHEEL BOLT
TOYOTA DRIVE PLATE
TOYOTA SUPRA CRANKSHAFT
TOYOTA AIR FILTER PIPE/CLIPS
BLITZ LM AIR FILTER KIT
COIL PACK BRACKET
TOYOTA COIL PACK CLIP
TOYOTA COIL PACK WIRE
WHIFBITZ 2JZ COIL PACK SET
6 COIL PACK BRACKET BOLT
FERREA 2JZ VALVE STEM SEALS
TOYOTA CAMSHAFT SEAL
TOYOTA POWER STEERING PIPE
TURBO OIL DRAIN HOSES
SUPRA TURBO INLET GASKET
SUPRA TURBO OUTLET GASKET
WHIFBITZ TURBO LINK PIPES - BLACK
ARP MAIN STUD KIT
ARP ROD BOLT KIT
PCV VALVE SEAL
CAM COVER BREATHER HOSES
PCV BREATHER HOSE
SILICON VACUUM HOSE
TOYOTA BOV HOSE
WHIFBITZ HEATER HOSES
WHIFBITZ RESTRICTOR RING
WHIFBITZ 1.3 BAR RAD CAP
UK SPEC FRONT BRAKE DISCS
UK SPEC FRONT BRAKE PADS
WHIFBITZ STAGE 1 TURBOS
TOYOTA MANIFOLD TO TURBO GASKET
TURBO TO Y-PIPE GASKETS
NEW RADIATOR
WHIFBITZ 71 DEG THERMOSTAT
+ all the appropriate oils and fluids etc.
it is Essentially a stock supra other than.
Double Decat (Both CATS included with sale)
induction kit
blitz nut spec r exhaust system (usual dents underneath, and has a flat spot on the tip)
Blitz Dual SBC boost controller
UK Brakes
Glass Headlights
Clear front indicators
Grenade17" Alloys (r34 skyline Replica wheels)
And is subtlety lowered.
Have a Walbro 255 fuel pump and XS power FMIC, and a spare diff that will be included with the sale.
Needs a FCD in order to turn the boost up, something along with the fuel pump and fmic I had intended on getting round to but never did. plus side is the hybrid turbos have never seen more than stock boost.
The car was an on going project that I had really hoped on finishing, and so it is going to be sold as one, mechanically it drives lovely and since its last MOT, last august I think I have done about 700 miles. Sadly however the bodywork is not the best, the bonnet in particular needs a respray however the whole car could do with it in order to make it the best it could be. It has blemishes and swirl marks etc as to be expected from a 23 year old car.
I have no photos of it as it stands but if they will help I will take some tomorrow.
What are your guys opinion on pricing? any vague price range would be great.
cheers
£29,995? I have seen said car for sale, and to be honest if its the one I'm thinking of then yes its a pretty rare find. But if it genuinely sells at that price I will eat my hat.
I was thinking 9 would be fair seems I have seen a lot of NAs for sale for around 6. thanks for the input.
