Help.... Car won't run above 2k
steve spedd
Evening all,
Wondering if the Supra experts can assist or suggest something!
Bit of background.... Cars a NA-t running an FFIM and was working perfectly.
Been off the road I'd say a month in which time I've fitted the following:
New steering rack
New front brakes
New bonnet (with holes/vents); suspect this is the issue
Anyway... Now the car won't rev above 2k; presume it's in limp mode? Now my initial thoughts were its electronic as it idles fine so could it be because something has got wet? If so what should I be looking at or what are the common parts to fail if they are wet? Granted I've not yet checked all fuses but doubt this to be that.
I have taken a little look at the map/TP sensor and looked wet but I've given it a good soak in WD-40 and didn't fix it. Not sure if this needs drying properly?
Any advice? booked in for a Mot Saturday
Thanks. Stephen
