MC_Bob Posted April 1, 2017 Share Posted April 1, 2017 Hi guys. Looking for a bit of advice. I currently have a good spec aristo, but Ive always wanted a supra. Ive had it for 5 years now, and will include a list of parts below. In my mind, can I buy a NA, auto Supra, and make it manual and single with my parts? Do I need to change the sump? This list I think definately all will bolt up? 2JZ GTE VVTI Vibratechnic engine mounts. HX35 Manifold Wastegate Syvecs S6 Stand alone management Big case Carbonetics diff 2way But then..: JZX90 MKII R154 Gearbox with extended shifter mount LS400 front brake setup Id really appreciate any help given. Nathan Quote Link to comment Share on other sites More sharing options...
ibby Posted April 1, 2017 Share Posted April 1, 2017 All of it Quote Link to comment Share on other sites More sharing options...
ibby Posted April 1, 2017 Share Posted April 1, 2017 With some modifications Quote Link to comment Share on other sites More sharing options...
Sandesupra Posted April 2, 2017 Share Posted April 2, 2017 yes the sump need to be swapped for a rear sump:-) Quote Link to comment Share on other sites More sharing options...
MC_Bob Posted April 2, 2017 Author Share Posted April 2, 2017 Thanks mate, Do you know about the gearbox shifter assembly? I think mine is 4-6 inches farthar back than a normal r154. Are there much I need to worry about on certain supras? Like are the N/A ones kitted out with low spec rear brakes etc? I think the LS400 brakes should fit as the supras fit the aristo too. Quote Link to comment Share on other sites More sharing options...
ibby Posted April 2, 2017 Share Posted April 2, 2017 Not sure about the gearbox. The rears won't take ls callipers. Quote Link to comment Share on other sites More sharing options...
G9RGE Posted April 2, 2017 Share Posted April 2, 2017 Im sure the jzx90 r154 fits the supra perfectly, its the mk3 supra r154 that needs the shifter extending. I think the loom harnesses are slightly different and maynot be plug and play but if its possible to wire a 1jz in then im sure its possible Quote Link to comment Share on other sites More sharing options...
MC_Bob Posted April 2, 2017 Author Share Posted April 2, 2017 Thanks buddy. Thats great! It is the furthest shifter you can get from toyota i think. although it does need reconditioning.. Since it all runs off syvecs I dont think the loom will be much of an issue either. Still cant find if engine mounts etc are the same. Quote Link to comment Share on other sites More sharing options...
G9RGE Posted April 2, 2017 Share Posted April 2, 2017 When i dropped a 1jz i know i used prefacelift na mounts over tge 1jz as the design looked far superior. I believe the sub frame mounting holes are the same on the soarer but not surcif the soarer is the same as the aristo.. The ls400 brakes just bolt on with a quick adjustment with a grinder, but its obvious where when fitting. Quote Link to comment Share on other sites More sharing options...
ibby Posted April 2, 2017 Share Posted April 2, 2017 The engine mount will be the same. The NA engine mounting places are different. Quote Link to comment Share on other sites More sharing options...
MC_Bob Posted April 2, 2017 Author Share Posted April 2, 2017 So are the subframes the same? I was wanting to buy an NA shell and drop all my gear into that. Cheers guys Quote Link to comment Share on other sites More sharing options...
Scooter Posted April 2, 2017 Share Posted April 2, 2017 I don't see why you'd swap in the subframe even if it was compatible? Re NA's and lower spec, main things that spring to mind are some NA's don't have ABS (in case that's an issue?) also the rear diffs only have one rear mount TT's have two. No biggy as the subframe has the hole to fit the second and bring it up to TT standard. Rear diff's are 'small case' with a small prop flange so depending on the aristo sizing you may need to swap flanges or get a tt prop? Quote Link to comment Share on other sites More sharing options...
kwalker705 Posted April 2, 2017 Share Posted April 2, 2017 supra NA and TT subframes are the same.. Obviously Aristo one is very different. Engine mounting brackets look like different part no's . But that doesn't mean they wont fit. might make the engine sit high or low in the bay perhaps. Quote Link to comment Share on other sites More sharing options...
V8KILR Posted April 3, 2017 Share Posted April 3, 2017 Im sure the jzx90 r154 fits the supra perfectly, its the mk3 supra r154 that needs the shifter extending. I think the loom harnesses are slightly different and maynot be plug and play but if its possible to wire a 1jz in then im sure its possible Nope, it's the JZX100 R154 that fits perfectly. Quote Link to comment Share on other sites More sharing options...
kwalker705 Posted April 3, 2017 Share Posted April 3, 2017 Nope, it's the JZX100 R154 that fits perfectly. Loom and harnesses are massively different. Aristo ECU sits behind headlight. supra ECU in passenger footwell. I'd imagine a VVTi supra harness will make your life a lot easier. MC_bob . You transferring over the Syvecs as well ??? Quote Link to comment Share on other sites More sharing options...
ibby Posted April 3, 2017 Share Posted April 3, 2017 A guy in the states can make an extender wiring loom to work with the aristo MK2 loom. But it's not cheap to buy but an supra loom isn't cheap either. Personally, i would just modify the na wiring loom to work with the aristo engine, swap out the aristo ECU with a TT ECU. Quote Link to comment Share on other sites More sharing options...
