(FIXED) Hit boost and car died.... now doesn't start...
Supra-love
If it is the igniter, I'd use the opportunity to ditch it the oem coils and igniter and fit GM LQ9 coilpacks (built in igniter on each coilpack, replacements cheaper than Toyota coilscoils)
Not seen them, nice solution and looks like PHR do mounting brackets too :thumbs:
Currently I've got the oem ignitor, super spark coils and ngk racing 9 plugs. Will definitely be upgrading the coil system at some point though
- - - Updated - - -
Anything else apart from the pump been changed?
Nothing else from my end mate. Just the pump.
Check that all your plugs spark, super sparks are known to fail I had a set only lasted a few years until giving missfire issues.
Do you have a fpr with gauge you would be able to tell you have fuel preasure, I know you said the plugs smelt of fuel but were they wet? Posible the impella of the fuel pump has come away not flowing fuel correctly
Edited by mellonman (see edit history)
Still waiting on the ignitor so I can check that. If that doesn't work I will check each spark plug for sparks.
I don't have a fuel gauge, I use the syvecs toucan for the gauges not sure it has a fuel presure one? I'm new to everything ATM.
Hang on a minute , just see the post about the fuel pump you have changed ? all the walbro 400+ have to have the 12v relay mod to work they cant run on the 9v supply from the stock fuel pump ecu.
http://www.mkivsupra.net/vbb/showthread.php?272714-12v-mod-will-this-work
http://www.mkivsupra.net/vbb/showthread.php?272695-cutting-out-after-fitting-walbro-400/page2
Well I must be odiotic, or having some moments in old age.
Basically I checked so much before I checked the fuel pump. Left it till last cause plugs were wet and getting fuel.
But, I pulled the fuel pump out and low and behold a pipe had blown off from the pressure, refitted and life arose again..
People fitting aftermarket fuel systems should consider adding a Schrader valve to the fuel rail to allow an external mechanical gauge to be "plugged in" for diagnostics and tuning. A lot of current cars have them for easy attachment of a gauge. EG: https://www.schraderinternational.com/Products/Product-Folder/EU-High-Pressure-Valves?sc_lang=en-US-E
I'm assuming that the Syvecs would have flashed up a fuel pressure warning if of a fuel pressure sensor was fitted?
Apparently not, lee and Ryan.g didn't mention anything after I sent the logs..
Saying that my syvecs and firmware is well outdated now, by like 5years, needs a major update.
