UK caliper part numbers ? ?
Steve W
Can anybody give me the part number(s) for the UK spec' front
Brake Calipers (and discs and pads preferably).
Just about to order a pair using someone elses UK Chassis, but,
would be nice to have the PART NUMBERS to double check THEM !
THANKS in ADVANCE ?
FatS.
BLIMEY ! !
that's a BIG ONE :p
ANY help is appreciated "U"...
I found an old post with some lists of part numbers (?)
BUT, I'll take any others 'cos I can double check....
[ gonna do the Jap'-to-UK Front swap....and poss' the rears, haven't
decided yet ! ]
FatS.
UK Left Rear Disk 42431-14150
UK Right Rear Disk 42431-14150
UK Left Front Disk 43516-14030
UK Right Front Disk 43512-14200
UK Left Rear Calliper 47750-14280
UK Right Rear Calliper 47730-14270
UK Left Front Calliper 47750-14270
UK Right Front Calliper 47730-14260
UK Brake Pads Front (both) 04465-14150
UK Brake Pads Rear (both) 04466-14040
UK Shim kit rear 04946-14030
UK Shim kit front 04945-14110
UK Fitting kit rear 04948-14010
UK Fitting kit front 04947-14010
You're just a KiNKY GUY who loves talking about Fluid exCHANGES
:p
Yeah, know what you mean, If I ever bleed brakes I always 'bleed'
the whole lot of fluid thru' anyway - might as well ? ! it only means
using 1 or 2 litres instead of 1/2 - 1 litre anyway !
im an advocate of full uk setup, but lately ive driven a set of jspec brakes with good fluid and race pads (for the first time) and i can honestly say its a complete transformation. much more so that i ever imagined was possible. i think its nearly as good as a full uk setup, less unsprung weight too, and alot cheaper. ive not got them to fade yet but they do squeal like hell. the uk setup looks much better behind the wheels tho.
got some prices toyota quoted me a while ago
is this every part number you need to go with uk spec,could ask toyota about a group buy discount see if they knock much off the price. he told me before he cant do group buys on japanese spec parts only on uk items.
UK Left Rear Disk 42431-14150 £91.58 excluding VAT
UK Right Rear Disk 42431-14150 £91.58 excluding VAT
UK Left Front Disk 43516-14030 (no price)
UK Right Front Disk 43512-14200 (no price)
UK Left Rear Calliper 47750-14280 £247.16 excluding VAT
UK Right Rear Calliper 47730-14270 £195.19 excluding VAT
UK Left Front Calliper 47750-14270 £195.19 excluding VAT
UK Right Front Calliper 47730-14260 £195.19 excluding VAT
UK Brake Pads Front (both) 04465-14150 £60.42 excluding VAT
UK Brake Pads Rear (both) 04466-14040 £55.62 excluding VAT
UK Shim kit rear 04946-14030 (no price)
UK Shim kit front 04945-14110 (no price)
UK Fitting kit rear 04948-14010 (no price)
UK Fitting kit front 04947-14010 (no price)
** UK Left Rear Calliper 47750-14280 £247.16 excluding VAT **
and, nobody knows why the Left Rear one is an odd price ? ?:conf:
Has it got an odd/different pipe connections or something ? ?:conf:
or, is it just Eastern-to-Western price cock-up ?:music:
(we've had thet at work with Kia parts - £175 for a Timing Belt,
but £3.50 for a complete set of Main Bearings ? ! ? dealer says
it's definitely translation/conversion problems but he didn't care ?)
THANKS for all the info so far lads....:thumbs:
ANYONE got any pics of the Jap'brakes and/or the UK brakes
(ON car / OFF car - anything - just like to see it all before I start)
FatS.
Originally posted by John Packham
Yes, but in the grand scheme of things - hub, disc, wheel, tyre - not a lot. A fixed four pot always beats a sliding caliper, and the pad area is quite a bit larger aswell. My vote says UK.
yes i agree, i was so amazed at how good the jspec brakes could b made, for little outlay.
