a98pmalcolm Posted March 27, 2017 Share Posted March 27, 2017 (edited) So a few of you know before xmas the Supra did a right number on me, but breaking one of the worst things to go, being the diff. Parts for them are very rare and expensive. One of the gears broke off during a launch wedging itself in the ring gear locking the wheels ruining the pinion and snapping the prop shaft well 3 months later and a solid day picking up completed parts and fitting, I finally have the on road with with an uprated prop, OS Giken diff, US spec pinion kit, solid shift bush and uprated rear diff bushes. A massive thanks to Lee Perryman and team at SRD for building my diff with some of the required parts so quickly, supplying me with the uprated SRD prop and all the advice. Paul Whiffin at Whibitz for supplying diff parts, the os giken diff and all the time taken with helping. Dan at my local Toyota for the pinon kit and track rods (damaged during recovery) And my work colleague (boss) Alex staying later after work yesterday to help with the start of the work on the car, me using his tools today and all the help with getting the stuff over the past few months. Well what else better than pictures now I guess. After removing the back plate, we found this Pinion trashed The remaining of the broken gear caused he damage to the pinon and crown I had the case sand blasted Os Giken Turned up Painted the case to prevent rusting and to make it look more presentable I also hand rubbed down the back plate to remove corrosion and painted that to suit the case Inner of the back plate all cleaned and inspected USA final drive kit Mt GF drove all my parts to Lee and the team at SRD to rebuild the diff Edited March 27, 2017 by a98pmalcolm (see edit history) Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted March 27, 2017 Author Share Posted March 27, 2017 (edited) All completed Damaged track rod during recovery As the rear wheels locked and the engine was still going it snapped the prop. Alex and I replaced both track rods, gators and clips Alex Fitted some aftermarket rear diff bushes that I manged to get hold of. ] Diff back in I changed my shifter bushes to solid ones due to how worn my OEM ones were. What a pig it was to remove this. SRD uprated prop shaft on Edited March 27, 2017 by a98pmalcolm (see edit history) Quote Link to comment Share on other sites More sharing options...
Supra-love Posted March 27, 2017 Share Posted March 27, 2017 Wow that really did make a mess pal, really glad you got it sorted, looks like a Nightmare in reality.!. Looks a lovely very job you've had done, will last for years to come now! Quote Link to comment Share on other sites More sharing options...
wrighty338 Posted March 27, 2017 Share Posted March 27, 2017 Good work Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted March 27, 2017 Share Posted March 27, 2017 Thats one of the worst failures on the torsen I've seen.. Regarding rebuilding the diff, what did Lee use for shims? The OEM shims are discontinued to my knowledge. Quote Link to comment Share on other sites More sharing options...
raddys Posted March 27, 2017 Share Posted March 27, 2017 My god that must of taken some serious cash to fix it.. well done for sticking through it though Quote Link to comment Share on other sites More sharing options...
Sheefa Posted March 27, 2017 Share Posted March 27, 2017 Ouch!! Still you have one of the best diffs available now and a great new prop too! Happy days. What were the make of the diff mounts mate as I'm looking at replacing mine and don't know what to get. Glad it's all sorted and see you at Japfest. Cheers Greg Quote Link to comment Share on other sites More sharing options...
blythmrk Posted March 27, 2017 Share Posted March 27, 2017 Ouch!! Still you have one of the best diffs available now and a great new prop too! Happy days. What were the make of the diff mounts mate as I'm looking at replacing mine and don't know what to get. Glad it's all sorted and see you at Japfest. Cheers Greg /QUOTE] Hi Greg They are Strongflex bushes I have them in my refurbished rear sub frame my only comment is they are fluorescent yellow! Thanks Mark Quote Link to comment Share on other sites More sharing options...
blythmrk Posted March 27, 2017 Share Posted March 27, 2017 All completed http://i.imgur.com/sCLH9u5.jpg Damaged track rod during recovery http://i.imgur.com/q0yNJeL.jpg As the rear wheels locked and the engine was still going it snapped the prop. http://i.imgur.com/XuIHlMV.jpg http://i.imgur.com/P4x04Mq.jpg Alex and I replaced both track rods, gators and clips http://i.imgur.com/E5aNdLe.jpg http://i.imgur.com/YRkZOFL.jpg Alex Fitted some aftermarket rear diff bushes that I manged to get hold of. http://i.imgur.com/cIA2Vgb.jpg] Diff back in http://i.imgur.com/gBK4aXv.jpg I changed my shifter bushes to solid ones due to how worn my OEM ones were. What a pig it was to remove this. http://i.imgur.com/Ldg0Kff.jpg http://i.imgur.com/7hHu09C.jpg http://i.imgur.com/CmNm02M.jpg SRD uprated prop shaft on http://i.imgur.com/kFcGX6G.jpg What a mess! but glad you got it sorted. I am just hoping that mine is the bearings as you said because mine is only whining still drives perfect. What do SRD charge for a diff build only if I supply all the parts the casings will be pre shot blasted and painted? Quote Link to comment Share on other sites More sharing options...
Annabella Posted March 27, 2017 Share Posted March 27, 2017 Jesus that was a mess! It'll be better than before now Quote Link to comment Share on other sites More sharing options...
T2 MSW Posted March 27, 2017 Share Posted March 27, 2017 That has right royally Shat itself. That it then the supra all set for DragonBall?? Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted March 27, 2017 Author Share Posted March 27, 2017 Thanks for the reply guys, yer its been a difficult few months and has set me back thousands. Yes Greg I will be booking for Japfst now See you there. Won't be doing Dragonball this year, hopefully next year Quote Link to comment Share on other sites More sharing options...
Mugello Posted March 27, 2017 Share Posted March 27, 2017 Thanks for the reply guys, yer its been a difficult few months and has set me back thousands. Yes Greg I will be booking for Japfst now See you there. Won't be doing Dragonball this year, hopefully next year Great work to get it all sorted - Looks perfect now! Out of interest whats the cost of the "USA final drive kit" Pm me if you prefer? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 27, 2017 Share Posted March 27, 2017 What a mess! but glad you got it sorted. I am just hoping that mine is the bearings as you said because mine is only whining still drives perfect. What do SRD charge for a diff build only if I supply all the parts the casings will be pre shot blasted and painted? The problem now is Toyota no longer stock the side shims, which is why I asked if you had the originals. if they are too thick I can grind them on the surface grinder, if too thin i have to use my very limited stock of used ones if thick enough, or my even lower stock of laser cut ones, which were expensive, and surface grinding is time consuming. So for a full rebuild like yours i would say "250 plu VAT, maybe more if lots of grinding needed. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 27, 2017 Share Posted March 27, 2017 Glad to see she is back up and running Malcom The problem now is Toyota no longer stock the side shims, which is why I asked if you had the originals. if they are too thick I can grind them on the surface grinder, if too thin i have to use my very limited stock of used ones if thick enough, or my even lower stock of laser cut ones, which were expensive, and surface grinding is time consuming. So for a full rebuild like yours i would say "250 plu VAT, maybe more if lots of grinding needed. PHR do peel away Shims , if they are any use https://www.powerhouseracing.com/product/5611/phr-peel-away-shim-for-supra-tt-6spd-rear-end-side-carriers Quote Link to comment Share on other sites More sharing options...
Big Mark Posted April 26, 2017 Share Posted April 26, 2017 Glad to see she is back up and running Malcom PHR do peel away Shims , if they are any use https://www.powerhouseracing.com/product/5611/phr-peel-away-shim-for-supra-tt-6spd-rear-end-side-carriers Just watched the video, seems interesting. Are they for big case or small case diff? Quote Link to comment Share on other sites More sharing options...
